| | #1 |
| Pebble Pounder Join Date: Apr 2008 Location: Tulsa
| I just installed two of the AX10 spool lockers and for some reason they feel like there is a lot of drag on them. I have not put the drive shafts back in yet. after I put the gears in and closed up the housing I used an allen wrench in the hole of the pinion to turn it and it just took more umph then I thought it would. On the website it does say "Note: Once you install these locker, it will make a bit of noise, but over time the noise will lessen." So is the just a side effect of what ever it is that is making the noise. When I put them in i did use a small amount of white lithium grease to lube it. I have used this in the past (on other lockers) and never had a problem with it. Are these just different? |
| Sponsored Links | |
| | #2 |
| On the lookout for Rocks ![]() Join Date: Mar 2006 Location: Monroe, Louisiana
| These lockers are tight, they will have to wear in. |
| | #3 |
| Rock Crawler ![]() Join Date: Nov 2004 Location: in a basement in Kalispell, MT
| Make sure you pinion and or inner pinion bearing didn't slide into the housing a little bit. Building my axles I didn't have the inner pinion bearing fully seated and it created lots of drag. |
| | #4 |
| From what I can tell they are in there all the way. They came with a new pinion gear that is all one piece unlike the stck ones that has a gear that fits over the shaft with the pins and e-clips. I don't think this one has any choise but to be all the way in. I gave them a good push when I was putting them in. I guess I will just drive it around in circles till it wears in a bit. thanks for the help guys. trying to get it ready for the comp in two days and I want to make sure it is top notch as I can get it. |
| | #5 |
| Pebble Pounder Join Date: Sep 2007 Location: Northeast
| It's the mechanical version of the drag brake. :-P |
| Thread Tools | |
| Display Modes | |
