Thread: My mods so far, Anymore suggestions
Old 06-12-2008, 04:47 PM   #1
Default My mods so far, Anymore suggestions
I bought this used and made some mods to it. I would enjoy some criticism, leter rip.
Here are some pics with the body on
Front view
Top View
Front before mod
Front after mod
I went to 4 link uppers in the rear, I took the existing servo plate and drilled and countersunk the holes, so i could still use the rear servo. I used the stock lowers for the upperlinks. I had to cut off about 3-4mm off of it to get correct angle. Here are some pics of that.
I also added a longer drag link on the rear as i did on the front.
Before
I flipped the servo
after
I bought some lower links and cut them to length
I took the antenna and changed the way it was ran
before
I ran fuel line around the chassis and ran the antenna in that
Thats it. Now for some input please, thanks.
tbizzle is offline   Reply With Quote
Old 06-13-2008, 12:00 AM   #2
Wow, no criticism, I must of done a good job. I am a newb when it comes to crawling. I got all the ideas from this forum. Thanks for the help.
A couplle of things i also did was add the losi claws, flip the rear shocks. I added the rubber stoppers on the inside of the shocks in the rear not the front. I also added 6oz to front and rear. Seems to work pretty well.
Old 06-13-2008, 12:39 AM   #3
looks okay i had a paint job similar to yours why didnt you buy bent links for the front also?
breitenbach14 is offline   Reply With Quote
Old 06-13-2008, 05:34 AM   #4
Looks really good so far. I like your antenna idea. Thought about adding a slipper? I love the way mine is working and no more twisted shafts, although, I do have a habit of matting it when it gets bound to see if it'll just hop out of the spot.....
Cajun is offline   Reply With Quote
Old 06-13-2008, 09:11 AM   #5
Looks great - my only suggestion is to replace the drive shafts with revo's - only if you're into comps.
Yawzer is offline   Reply With Quote
Old 06-13-2008, 05:59 PM   #6
Looking good so far! One question about your 4 link servo plate. That is the stock plate, right? If so how far in from the edge did you mark for your holes? I want to try this on my stock rear plate. Thanks!
chops1sc is offline   Reply With Quote
Old 06-13-2008, 08:27 PM   #7
Yes, its the stock plate
Measure the radius of the screw then measure that from the ege of the plate.
For the width i drew a center line and then i divided that by two. You have to cut a few mil of the links to get correct drive shaft angle. You will also need to tap it with a 3 mil.
I tested on a rock before going to 4link and it would torque twist right off the rock. Now i can go up the rock with no problems.
Old 06-13-2008, 08:30 PM   #8
Not into comps.......yet i will do the drive shaft upgrade then. Have you heard of the mip shafts, are they anygood?
Old 06-13-2008, 08:32 PM   #9
Sounds like cheap insurance, I will do that, thanks.
Old 06-13-2008, 08:33 PM   #10
Havent got there yet, but its on my list
Old 06-14-2008, 01:11 PM   #11
Thanks tbizzle!! I'm drilling the holes today. BTW: I see you drilled a couple different holes for the uppers to connect to the chassis. The hole they are in now work best for you? I have drilled the holes that the stage 2 kit suggests. Just wondering. Thanks again!
