Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: R2D and DX3 set up help ??????
Old 06-16-2008, 07:32 AM   #1
shockwave's Avatar
Default R2D and DX3 set up help ??????
If possible, what is the easiest way to set the dx3 up to use disco as well as rear lock out. Got everything mounted, now I just need to set everything up. Any help would be great. Thanks guy's.
shockwave is offline   Reply With Quote
Old 06-16-2008, 08:31 AM   #2
i have the DX3 and an R2D, read the remote manual. look in the 3rd channel area and your looking for 3P (3 position). that should be enough info to get you started.
BuzzKilla is offline   Reply With Quote
Old 06-16-2008, 09:12 AM   #3
shockwave's Avatar
Thanks buzz, I kinda jumped the gun. The search button provided info as well. Thanks
Old 06-16-2008, 09:34 AM   #4
Giveaway Kang!!!
TEDROCKZ's Avatar
If you have some soldering skills this is the Hot Ticket for the DX3
3rd Channel Mod
TEDROCKZ is offline   Reply With Quote
Old 06-16-2008, 11:30 AM   #5
shockwave's Avatar
Thats what I was looking for. Thanks Tedrockz.
