Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: How Much Is Too Much?
Old 06-16-2008, 04:16 PM   #1
Default How Much Is Too Much?
I have been reading alot of the post about limiting articulation?(sp) and I was wondering how much is too much? Because right now I can stand one tire on 3 rock lizards while the front 2 are flat on the ground along with the opposite tire touching the ground as well. Is this too much?
Alarm God is offline   Reply With Quote
Old 06-16-2008, 04:29 PM   #2
Drive It And See How You Like It.
BILLYGOAT is offline   Reply With Quote
Old 06-16-2008, 04:58 PM   #3
Still waiting on the motor, its running stock motor right now. But it drives ok. Running Hitec 645MG, CC Sidewinder 1/10 ESC, CCBEC, TP1320 11.1 Li-Po, Losi Rock Claws, Stock Rims, Homemade Links, Proline Baja Bug Body, Stock Chassis. Waiting on Integy 55t, and CC USB programmer.
Old 06-16-2008, 07:11 PM   #4
alot of it depends on where you crawl at.
Testykalz is offline   Reply With Quote
Old 06-16-2008, 07:53 PM   #5
To me it all depends on how you drive. I tried out some fairly short travel shocks on mine here a while back, and just ended up turning it over everytime I tried something. Switched back to my original shock setup and I can control it alot better. Some of that is different for everyone, but I do know the stock shocks need some limiting. Mine are limited to about twice what the stock bump stops are, and limited inside the shock.
MCSCOTT is offline   Reply With Quote
