| | #1 |
| Rock Stacker Join Date: Jun 2008 Location: Eureka
| are their interchangeable diff gears? or different gear ratios that anyone makes? just curious thanks guys |
| Sponsored Links | |
| | #2 |
| Pebble Pounder Join Date: Jan 2005 Location: Oklahoma City
| Not that I'm aware of.... Why? Because its alot easier to change pinion/spur combo than changing diff gears. |
| | #3 |
| i understand that part but it would be nice for a really low gear combo. what spur gears do you guys run where can i buy a larger one that will fit? and are the mt2 gears really interchangeable? |
| | #4 |
| Rock Crawler Join Date: Jul 2008 Location: San Diego
| Does anyone make lower gear ratio gears for the AX 10? I think a 9/44 would take alot of stress off of the driveshafts! Then we could break the axle shafts!! Matt |
| | #5 |
| Rock Crawler Join Date: Apr 2007 Location: Denverish
| | #6 |
| I was talking about the gears in the diff. Matt |
| | #7 |
| Rock Crawler Join Date: Sep 2007 Location: Denmark
| HPI has harden´d diff gears that will fit in the ax-10 They also have one with a 36T/14T ratio .... but that will make the car go FASTER :-( |
| | #8 |
| Newbie Join Date: Jun 2008 Location: Kahala
| These may be the same ratio, but have anyone tried these?? Everything is one peice...but How do they perform? http://www.integy.com/cgi-bin/webc.c...d=5523&p_catid= |
| | #9 |
| Those look´s like they just might work |
| | #10 |
| Thanks for the Information-I will check into it! Matt |
| | #11 |
| Integy Emailed me back and they will make some lower gears for the diffs Matt |
| | #12 |
| Quarry Creeper Join Date: Apr 2008 Location: Houston
| | #13 |
| Quarry Creeper Join Date: Apr 2008 Location: Alexandria
| Hopefully someone else will design some, a lot of us have had such bad experiences with Integy in the past that we wont buy anything from them. Just be careful, there products are ok unless you get something that was machined wrong or doesn't fit, there customer service would be better if they didn't have any that it is with what they have. |
| | #14 |
| There is alot of copy cat stuff here. If they made lower gears, someone will else will copy it and make it. Matt |
| Thread Tools | |
| Display Modes | |
