Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: Servo mounting question
Old 06-18-2008, 03:50 AM   #1
Default Servo mounting question
Just wondering if mounting the servo using only one side is ok? If clearance is and issue could I just use one side of the servo to mount it or will there be to much load on that one side and cause it to fail?
HiloDB1 is offline   Reply With Quote
Old 06-18-2008, 04:16 AM   #2
MWRCA'er
Mnster's Avatar
Yeah only one side will not have enough support. What would probably happen if you used one side to support it would be that the servo would slop spin around. As a result it would snap the bracket off the side of the servo. If you must run only one side I would glue the servo to the mounting plate to avoid the shifting flexing around.
Mnster is offline   Reply With Quote
