06-22-2008, 01:11 PM | #1 |
| Pinion VS Motor
On an AX-10/ In terms of wheel speed, what would the difference be between a 17 tooth pinion and 55T motor or a 14 tooth pinion and a 35T motor? With 7.4 volts, which setup would be torquier and which do you think would get better run times? Thanks... |
06-25-2008, 06:03 PM | #2 |
Rock Stacker Join Date: Jun 2008 Location: Rancho Cucamonga
| Theres alot of choices, im running axial tranmissions in both my crawlers. i have a 21 tooth pinon with stock spur and 45 turn motor and get sick torque out of it! and im running 7.2 3000 mah batteries deans. I also am runnning a 55 turn with totally stock gearing and notice that the 45 is has more torque when there isnt a huge load but when the tire gets real bound up the 55 has more power but the 45 has more hop. The best gearing set up i ever ran was on my wheelie king with a 45 turn mtr 21 pinon and 96 th spur.. it had torque and speed but i noticed that my stock esc also got a bit hot so i had to upgrade. hope that helped.
06-25-2008, 06:38 PM | #3 |
Wow. That's a big pinion. I tried a 17 tooth and it barely fit. How did you get one that big in there?
06-26-2008, 01:33 PM | #4 |
| i had no problem at all, the stock one that comes on the axial rtr should be a 20 tooth pinion, and i just took the one off of my wheelie king and thats a 21 and it fit right in...thats really wierd. send a pic if you really cant fit it in ... i have never had a problem. anybody else encountering this problem? otherwise my advise is run a 45 turn motor with 20 to 21 pinon with stock spur...(should be a 87th i believe) you get nice torque with a bit more top end to gun those hills and hop if you need.
06-26-2008, 01:47 PM | #5 |
The AX-10 kit comes witha 14 tooth pinion standard. I stole the 17 tooth off of a TLT I had sitting around. Anyway... I have decided to keep the 14 tooth and the 55T motor, but switch battery systems to a 3C Lipo. |
