06-24-2008, 11:10 PM | #1 |
Rock Crawler Join Date: May 2008 Location: Sumter, SC
| Leftover parts?? Rear steer!!
I was staring at my AX-10 and a pile of leftover parts from the build and the stage 2 upgrade today, and I thought to myself "self, what can I do with these parts?". The answer came to me.....REAR STEER! So I got my spare servo and mounted it to see what I needed to make the parts work. Then I started looking at the parts I had available. 4 55mm links, stock rod ends. I figured one 55mm link for the drag link and 2 55mm links together for the tie-rod. Plus all the junk needed to assemble. 3-55mm links (stock uppers) 4-rod ends (kit leftovers) 4-traxxas balls (from my revo) 3-3mm locknuts 1-3mm standard nut 3-3mm flat washers 1-3X25mm cap screw 2-3X15mm cap screws 4-3X15mm cap screws (for cutting) 1-3X20mm cap screw (for cutting) Now the first thing I did was make the screw connectors for the rod ends. I have lots of screws in my parts bin and got together 4-3X15mm and 1-3X20mm cap screws out and proceeded to cut the heads off. I then used the standard 3mm nut to clean the cut end of the threads. The I put the traxxas balls in the rod ends...... Then I assembled the links like so... Tie-rod: (note the 3 flat washers inbetween the links. this was to make the length of the 2 links 111-112mm) Drag link: This is how it looks laid out before installing it... Then I installed it on the rear axle.... This was surprisingly easy to do and very cheap (as long as you have an extra servo). Any questions, comments?? Last edited by chops1sc; 06-24-2008 at 11:32 PM. |
06-24-2008, 11:22 PM | #2 |
I joined the Band! Join Date: Dec 2007 Location: cotati
i think the tierod would be 106mm same as the front.... |
06-24-2008, 11:32 PM | #3 |
| You are right, I had a brain fart, lol. The length of the rear tie-rod is actually 112mm. The longer length gives me a slight toe in. I also have my rear axle tilted upwards so the rear shaft will clear rocks but the angle isnt terrible and after all its only rear steer. I control it with the 3p on my DX3R. Thanks for the heads up on my little error there. I fixed the error BTW. |
06-25-2008, 04:35 AM | #4 |
Newbie Join Date: Feb 2008 Location: somewhere in ontario
I put rws on my ax10 with basically leftover parts. If you want more steering on the back, bent rod ends and a straight tie rod (no bump in the middle) will let you turn more withour the tie rod hitting on the differential. But that can come later. Looking good
