06-27-2008, 07:55 AM | #1 |
Newbie Join Date: May 2008 Location: la puente
| Boomerang servo plate from TCS
bought a boomerang 4link mount (aluminium) front and rear for my ax10 from TCS. what else do i need to buy or modify to fit this boomerang to my ax10 kit
06-27-2008, 08:00 AM | #2 |
Pebble Pounder Join Date: Sep 2007 Location: Northeast
Is it the aluminum or delrin upper 4 link mount? If so, this replaces your stock servo plate in the rear if you are not using rear steer. It is not a servo plate and should be a bolt-on in place of the stock plate. I suppose you could attach it under the stock plate if you want to use it in the front with a 4 link setup. Last edited by jmbones; 06-27-2008 at 08:03 AM. |
06-27-2008, 08:05 AM | #3 |
RCC Addict Join Date: Oct 2007 Location: Commerce Twp.
You use the stock links, and just replace your stock servo plate with the boomerang plates and add rod ends to your upper links. |
06-27-2008, 11:32 AM | #4 |
You need a boomerang in the rear and a 4 link servo plate in the front. Aluminum http://www.tcscrawlers.com/TCS-Alumi...g-p-16613.html Delrin http://www.tcscrawlers.com/TCS-Delri...g-p-16526.html |
