07-02-2008, 09:57 PM | #1 |
Rock Crawler Join Date: Jan 2008 Location: Arlington, TN
| steering setup
I keep breaking the left side knuckle were both links connect, i have a set of aluminum ones on order but is there a better way to do the steering linkage as i dont want to start breaking the alum knuckles. the servo is a jr9100t and has been moved to the right for placement of a lipo. are there any advantages of using a split linkage? does the split linkage give more ground clearance and make it easier on the knuckle arms? here is a pic of what i have. or will this linkage set up work better? |
07-02-2008, 10:28 PM | #2 |
RCC Addict Join Date: Aug 2005 Location: VARCOR
Does your TX have EPAs? The 9100 is a pretty torquie servo, and without properly setting the EPAs, could easily put a hurting on plastic hubs.
07-03-2008, 07:12 AM | #3 |
ya im running a dx6 radio with the epa's set, they seem to break when i get bound up on the rocks... it actually bends the steering arm were the 2 links meet...thats why i was wondering if having each link mounted low on the arm would help with the twisting?
07-03-2008, 08:13 AM | #4 |
Quarry Creeper Join Date: Nov 2007 Location: Bozeman, MT
It looks like you have both links above the knuckle - this puts extra strain on the arm - try putting one above and one below - I did this before I got the aluminum ones - worked good.
07-03-2008, 09:46 AM | #5 |
I'll try that tonight, |
07-09-2008, 08:25 AM | #6 |
so did you try anything different? I don't think my Hitec 645 will break a knuckle, but I'd still like to pretty much copy your rig. JUST KIDDING
07-09-2008, 10:11 AM | #7 |
| Ya i got a set of alum c's and kncukles....lol i just hope the jr9100t doesnt break them.......lol now to upgrade the shocks...... |
07-09-2008, 11:05 AM | #8 |
Pebble Pounder Join Date: May 2008 Location: El Paso
| It shouldn't break them but you need to sandwich the knuckle with the steering rods.....i have never broken mine and i have a 333oz servo
07-09-2008, 12:05 PM | #9 |
varcor.org Join Date: Aug 2005 Location: 757
the single rod setup you have pictured is mine. i've had no problems with the knuckles but they are aluminum. i'm sure if they were plastic, i would break them especially since i used spacers to move the steering rod high. the spacer increase the leverage on the knuckles. however, i had your setup before with the tie-rod and drag-link above the knuckles and never broke a set, even with a 333oz servo. i think the issue is just the strength of the plastic knuckles so swapping them to the aluminums you should be fine. |
07-09-2008, 12:08 PM | #10 |
RCC Addict Join Date: Jun 2008 Location: Mudville
the z9100 is about what 340 or 380ish in/oz of torque? thats alot of torque. if your bound up and there is no give in the steering system, your either going to brake, bent some thing, pull out the threaded rod on one piece, or burn out the servo. in this situation, wouldnt a servo saver be a good thing? it would need to be adjustable somehow, but set it up so it is very stiff. so in most cases it shouldnt effect steerting, but in those cases like above, getting the tires pinched in, the servo saver would give at the high end torque instead of bending/braking a part, or burning up a servo. is there an adjustable servo saver for these units on the market? |
07-09-2008, 12:39 PM | #11 | |
Moderator Join Date: Jul 2007 Location: Texas baby!
In all honesty you really should be able to tell when the servo is stalling out, when that happens, let off the steering a bit. $100 bucks for a servo is quite a bit for me and I treat them nicely. Don't be stupid with it and you will be fine. | |
07-09-2008, 01:17 PM | #12 | |
