07-10-2008, 09:53 PM | #21 |
Rock Crawler Join Date: Feb 2008 Location: Golden Corral getting Fat
I am doing better with this chassis than my old GC-2 it is very stable and calm not so twitchy as others I really like it Big test next week at fairborn Ohio the battle grounds |
07-11-2008, 12:01 AM | #22 |
RCC Addict Join Date: Nov 2007 Location: CALI "209"
looks good will be watching this thread for any updates
07-11-2008, 04:58 AM | #23 |
RCC Addict Join Date: Oct 2007 Location: Commerce Twp.
Twistedone, how can you call your GC-2 old you just got it, what 3-4 months ago. LOL Good luck at the Battle Grounds.
07-14-2008, 10:00 PM | #24 |
i ran this chassis this weekend and it was fine the driver was bad but the truck was working awesome for the first comp it was in I have changed some shock stuff went to 40wt all around and here are some pics of what I think might help also added the tcs 4link and it freed up alot on the chassis |
07-15-2008, 01:05 AM | #25 | |
Quarry Creeper Join Date: Jun 2008 Location: Lapeer
| Hmmmmm, okey I see that, thank's Bob for the tip... Quote:
07-15-2008, 06:36 AM | #26 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
Looking good there Bobby. Got mine lined up...the Revo shocks are just a touch short for my droopy ways. So I'm getting that fixed tonight. Did you find the flat head screws for the Axial tranny to be too long? Or is it just me? |
07-15-2008, 07:28 AM | #27 |
Jake screws were ok in my stuff |
07-15-2008, 07:44 AM | #28 |
First Black widow build I've seen nice job. Interesting body mount idea and great paint. let us know how it works for you.
07-15-2008, 07:58 AM | #29 |
I wanna be Dave Join Date: Dec 2006 Location: Where the sheep run scared.
I have recently built a black widow myself using Losi shocks. I first had my shocks set like you are showing and the rig seemed a bit stiff. I pulled a spacer out to give them just a tad of inward lean and seems to do much better. I would like to add that you can easily flip the losi's and use them with your current mounting position at the axle.
07-29-2008, 11:05 PM | #30 |
| update and dig added
i have been crawling like a mad dog and have been changing some things and asking some questions . thanks for the help Jake,offroader,and mfm i have found a awesome spot for a fullsize servo on this chassis with a dna dig also here are some pics |
07-29-2008, 11:06 PM | #31 |
i have also switched to a droop set-up and some 3000 weight oil in rear and 1000 in front this is working awesome so far
07-30-2008, 06:18 AM | #32 |
I had the same idea for dig servo placement, my problem is how low I like my body. Great thinking Bobby! Glad to hear the Droopy has helped make it more stable. Now you just need Revo shocks. I run 25wt and its slow! |
07-30-2008, 09:59 AM | #33 |
RCC Addict Join Date: Feb 2008 Location: Hiatus..sutiaH
I am not for hijackin but I gotta know this. I have a vf that I set up for my stock Axial chassis. I had to cut the rear DS a lot to get it to fit/work. When I upgraded to the MFM chassis I noticed that they placed the tranny mounting points on the skid way up front. So not only will the cut shafts not fit it looks like the one OEM one is too short. I just ordered Maxx shafts though so that doesn't matter. But, do you have enough travel/length with the VF/Axial shafts? Great idea about the servo as well. I am working on something similar. Thanks for all the progress posts. |
07-30-2008, 10:38 AM | #34 |
RCC Addict Join Date: Jun 2008 Location: Fresno
ive been wanting to pick up one of these chasiss' is there anything i needed to buy along w/ the black widow chassis? im currently running rtr ax 10 w/ losi crawler shocks and alumuminum lower links i pmed casey over at mfm and was told i needed to get 102 mm revo pushrods. but when i do a search for them i'm not coming up w/ anything. can someone point me in the right direction? besides the puch rods is there anything else i needed? |
07-30-2008, 10:44 AM | #35 | |
buy the rustler shocks or run stock as droop I did the tcs 4 link plates and thats all sku 26890 sku 16523 | |
07-30-2008, 10:56 AM | #36 |
| I run the Rustler shafts which are shorter than the Axials...no cutting and perfect length.
07-30-2008, 11:10 AM | #37 |
so i shouldnt use the losi crawler shocks? damn! i just bought these this weekend |
07-30-2008, 11:26 AM | #38 |
they will work i just liked going to droop and the axial shocks its what you like there will be 5 guys tell you 5 different things so run what you like you will get it right for you |
07-30-2008, 11:45 AM | #39 |
Losi shocks will worik fine for droop on this chassis. I'm using the shortest, Revo for droop without too many issues.
