07-09-2008, 08:53 AM | #1 |
Newbie Join Date: Jul 2008 Location: ellijay
| need some help on my first crawler
hey, i got a axial ax10 artr and i am really happy with it but it is kinda stiff do i just need new springs or do i have to get a whole new shock/ would be great if you could help , thanks. |
07-09-2008, 08:58 AM | #2 |
Pebble Pounder Join Date: May 2008 Location: El Paso
you can swap the springs out, i use super soft up front and mediums out back, kinda helps with the torque twist.......and you can play with shock oils too!
07-09-2008, 09:00 AM | #3 |
ok thanks ill play around with it and see what happens |
07-09-2008, 09:20 AM | #4 |
Rock Crawler Join Date: Aug 2007 Location: Columbia, TN
Play with some different springs to see what you like. Also add some weight to the tires if you don't have it already and that will make it flex easier too.
07-09-2008, 06:55 PM | #5 |
ok thanks, do you have any advise on streching it a lil |
07-09-2008, 07:03 PM | #6 |
Quarry Creeper Join Date: Apr 2004 Location: west sacramento
ok here is what i see alot of guys running spring wise. super soft(red) front and right rear run a stock one on the left rear as for oil 30 in right rear, 60 in the left rear and 20 in the fronts. as for stretching it it's all about the links but with a bigger wheelbase you would be in a super class instead of the 2.2 class. weight in the tire's is going to help alot i got my stick on wheel weights from the local tire shop for free.i made 2 full runs around the inside of the rim on the backs and 3 full runs around the front wheels. you will see what i am talking about when you get started.have you cut your foams and drilled your rims with 1/8th holes? that will help with gripping
07-09-2008, 09:21 PM | #7 |
ok , thanks no i havent drilled holes yet but planning to do i still need foam if so what kind i no theirs a couple dif kind out their |
07-09-2008, 09:30 PM | #8 | |
I wanna be Dave Join Date: Jun 2005 Location: drillin Holes for the man
If you have the ARTR I wouldn't cut the foams as they are prolines memory foams. They are really soft already and after you add some weights to the inside of the rim they should be about perfect. There are better foams out there but the ones that came with it will do you just fine. | |
07-09-2008, 09:38 PM | #9 |
ok thanks how much weight shount i add to the front / rear sombody told me to use three go arounds o/n each rim on front and too on the back |
07-09-2008, 09:41 PM | #10 |
| on mine I used 6oz in the rear and 10oz up front. I think I am going to add about 3 more oz.s to each front though cause my rig is really light and need more traction for steep climbs.
07-09-2008, 09:47 PM | #11 |
ok thanks i think im set on the suspinsion what aftermarket chassis do you recomend i was looking at the tcs edge . |
07-09-2008, 10:58 PM | #12 |
Newbie Join Date: Jul 2008 Location: Ft. Lauderdale WHere the sun does shine
Why the different rates in the left rear?? |
07-10-2008, 06:05 AM | #13 |
07-13-2008, 04:18 PM | #14 |
Thanx for the info and advise. Didn't mean to steal the thread. But was very curious. And if I have RC4WD alloy wheels, do I still need to add this kinda weight to wheels??
07-14-2008, 01:35 AM | #15 |
| theres alot of things you can do to the rig with the stock chassis to gain performance before you replace it. But if you are dead set on getting an afftermarket chassis then I would probably go with either the Black Jack or the Top bananna. They seem to be really well thought out and from the comp. stats they are performing excilently. If you want a tuber the either go with the fat dog or the Hustler.
07-14-2008, 09:49 PM | #16 |
