07-10-2008, 06:26 PM | #1 |
Newbie Join Date: Jun 2008 Location: berry
| help! What shock oil do I need?
I have my ARTR on its way. First thing when I get is is intall the CKRC stage 2 kit. And move the shock limiters to the inside of the shock. I will probably lose some of the shock oil or maybe will just replace it with new. I gotta go to the LHS tomorrow and grab a servo so I wanna get some while I am there. What weight comes in the stock shocks or what do you guys use? If you use different weights in different shocks you can let me know too. This is for the stock axial shocks. I searched but I really dont have time to read everything tonight. Thanks.
07-10-2008, 06:32 PM | #2 |
Newbie Join Date: May 2008 Location: Staten Island
start with 50.
07-10-2008, 06:37 PM | #3 |
Quarry Creeper Join Date: Apr 2004 Location: west sacramento
60 in the left rear, 30 in the right rear,20 in the fronts
07-10-2008, 06:37 PM | #4 |
Thanks for the quick reply I will start with 50. I might pick up some fuel tubing to use for the shock limiters then I can customize the length to adjust ride height.
07-10-2008, 06:44 PM | #5 |
Do you guys know the stock weight?
07-10-2008, 07:33 PM | #6 |
Rock Crawler Join Date: May 2007 Location: lacey
stock is 30wt I am running 90.
07-10-2008, 08:57 PM | #7 |
thanks, Stock is 30 you run 90 so I guess I will go ahead and try 50 and maybe some heavier for the rear left. It'll be a start anyway.
07-11-2008, 07:34 AM | #8 |
try not to use diffrent wt oil. u want to keep it as symetrical as u can
