Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: Stock Axial 27T and stock Axial motor plate
Old 07-14-2008, 03:29 PM   #1
Default Stock Axial 27T and stock Axial motor plate
Am I missing something or is the stock 27T Axial motor supposed to fit into the oval hole on the stock Axial motor plate? I just got a stock motor and it doesn't bolt up to the motor plate. Is there an adapter that I'm missing?
jmbones is offline   Reply With Quote
Old 07-14-2008, 03:35 PM   #2
Just run a sanding drum on a dremel through the hole a few times or use a little file, its not uncommon for motors not to fit into motor plates like that, similar on the AE B4 buggy.
josh_smaxx is offline   Reply With Quote
Old 07-14-2008, 04:22 PM   #3
Got it, Thanks!
