Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: my comp ax10
Old 07-19-2008, 04:04 PM   #1
Default my comp ax10
chassis:
stock ax10
suspension:
stock shocks with spacer under the piston
stock rear springs with ckrc soft springs up front
ckrc 4-link plates front and rear
ckrc heavy-duty bent rear links
moded skidplate to bring the bottom links inside
axles:
heavyduty axial lockers
electronics:
cc sidewinder
integy 55t motor (soon to be 45t)
hitechs-985mg steering servo
thuner power 1350 mah 11.1 lipo
jr 2 chanle radio
tires,wheels,body:
proline m3 badlands
stock axial beadlocks
hpi bug body
on to the pics
Click the image to open in full size.Click the image to open in full size.
mattman is offline   Reply With Quote
Old 07-19-2008, 04:26 PM   #2
how is that body comp legal with the nose like that?
drilldeep is offline   Reply With Quote
Old 07-19-2008, 04:43 PM   #3
darn your right,
oh well i gess ill have to get the losi grappler or something then.
Old 07-19-2008, 04:49 PM   #4
sweet lookin rig nontheless!!!!!
Old 07-19-2008, 05:11 PM   #5
thanks
and do yall think it would be good enough for local comps or will it need more work to it?
Old 07-20-2008, 12:52 AM   #6
i dont know where you are crawling...its a darn good start tho...and i dont know your driving skill either. personally id soften up the rear springs as well, if those are the stock axial springs...get the soft or super softs... get weight in the wheels and down low...more in front as well. hit a comp and see what your competition is doin and what is working and go from there!!!! good luck!
