Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: My Fatdog belly dragger
Old 07-19-2008, 08:13 PM   #1
Default My Fatdog belly dragger
I got my rig presentable so I figured I'd whore it up and show it off!
It is a Fatdog tuber with Axial axles and transmission. It has an 11.75" wheelbase.
Suspension:
Stock axial droop front (60wt oil with Ace hardware springs)
Losi threaded shocks with yellow springs
Traxxas Jato 61mm lower links
Axial 55mm upper links
TCS front and rear 4 link mounts
Drivetrain:
Axial Plastic Straight axle kit
Axial Straight axles
Freak Stuff Racing lockers (front and rear)
Traxxas Stampede driveshafts
87/14 Spur and Pinion (good crawl, but still some wheelspeed)
DNA Products Dig unit
Electronics:
Hitec 5645MG for steering
Hitec 225MG for dig
Novak 55t motor
Novak Rooster Crawler
TQ3 (modified with 3 way switch and EPAs)
Traxxas RX
Wheels/tires:
Axial beadlocks/losi claws (3.75 oz in each front)
Axial Beadlocks/Proline Flat Irons (3.75 oz in each front)
Pics:
First comp I went to with it (I had everything minus pede shafts and dig), I did fairly well for not having a dig. Next comp is August 9th and hopefully I can get a lil higher in the rankings!
I am extremely pleased on how it performs, my only complaint right now is every once and awhile it'll glitch. I am pretty sure it is the way I have the antennae set up (laddered then the tip sticking out).
Please feel free to comment or criticize.
Testykalz is offline   Reply With Quote
Old 07-19-2008, 08:24 PM   #2
the clitch might be the novac crawler they had problems with some of the first runs. do a search on it
stevew is offline   Reply With Quote
Old 07-19-2008, 09:14 PM   #3
Yeah, I thought that too but it didn't do it on the stock chassis. Its something ive done since then! lol
