Thread: gearing question?
Old 07-25-2008, 04:12 PM   #1
Default gearing question?
I have an ax-10 based tuber it has 1.9 size tires. Its going to be a rock racer I want it to go 20+mph what gearing do i need spur/pinion/motor.
SUPERCLODBUS is offline   Reply With Quote
Old 07-25-2008, 06:53 PM   #2
To get that kind of speed out of an AX10 drive line you would need a final gear ratio around 15:1 or lower, depending on motor and bat combo. To get that low you would need a spur pinion ratio around 2:1 ( 30T pinion to 60T spur or what ever combo you can come up with) As far as motor, a 12T brushed or 5600kv brushless should do the trick.
ThunderVP is offline   Reply With Quote
