08-18-2008, 06:46 PM | #1 |
Newbie Join Date: Jul 2008 Location: toledo
| hbz warhog
anyone have any idea of shock setup for this springs or droop? im running stock axial shocks and they seem to high
08-18-2008, 06:47 PM | #2 |
Quarry Creeper Join Date: Apr 2008 Location: Alexandria
Are you running a spacer on the inside of the shock body to bring them down a little bit?
08-18-2008, 06:58 PM | #3 |
no ill have to try that for now i think i may go droop to see if i like it. i really just wanted o know if it was working for anyone
08-18-2008, 08:58 PM | #4 |
I wanna be Dave Join Date: Mar 2004 Location: The Haunted Forest
Spacer in the shocks is a good setup, or you could run the Losi crawler shocks with the longer Jato ball ends or Tanis's end mod.
08-18-2008, 11:51 PM | #5 |
Rock Crawler Join Date: Nov 2007 Location: Bay Area (RWC)
I am in the middle of building my Warthog and the shocks I mounted up were the Traxxas Big Bores with the AX10 shock rods with the stock rubber spacer on the inside. This was too low. Somewhere around 1 3/4 ground clearance. Then I took the spacer out and the ride height rose a tad over 2 1/8. It seems this would be the lowest I would try. I did order the 120mm HR shocks to see what that does. But it seems the 4" shocks with the AX10 shock rods is a place to start.
08-19-2008, 10:43 PM | #6 |
Newbie Join Date: May 2008 Location: eagle rock
im running Losi Crawler shocks w/ Axial Shafts.
