08-22-2008, 07:09 PM | #1 |
RCC Addict Join Date: Jun 2008 Location: Fresno
| bent rod ends?
recently ive been swapping out my axial rod ends to traxxas rod ends. i was just wondering of traxxas made a bent rod end. i mainly need it for the 109 mm steering rod . ive tried to use the the regular straight rod end but it drastically limits my steering travel because the rod hits the pumpkin, even when my knuckles have a couple more degrees left in them. i know i can bend the link, but would rather not. i want want my steering links to be straight to keep it stronger any suggestions anyone? |
08-22-2008, 07:20 PM | #2 |
I wanna be Dave Join Date: May 2006 Location: FOUR 8 OH
I haven't found any Traxxas ends with bends like the Axial ones because I'm about to do what you are an noticed that as well. I might run the stock steering for a while and then upgrade to something like the Integy or STRC steering links.
08-22-2008, 07:51 PM | #3 |
Rock Crawler Join Date: May 2008 Location: Mansfield, PA
I have used these http://www.amainhobbies.com/product_...oducts_id/9722 ....they are (expensive) top quality "bent" rod ends from Mugen MBX5T Prospec truggy steering links. |
08-22-2008, 09:27 PM | #4 |
I wanna be Dave Join Date: Aug 2008 Location: Deep in Swing Town
you can put a 4mm spacer under the rod end to get the link up higher so it wont hit the pumkin |
08-22-2008, 09:39 PM | #5 |
08-22-2008, 09:54 PM | #6 | |||
a link would help | |||
08-22-2008, 10:50 PM | #7 |
i run mine like that, and it does nothing but raise up your steering rod and get's it that much more out of the way... the JR8711 i think can take it Last edited by roksloski; 08-22-2008 at 10:52 PM. |
08-22-2008, 10:51 PM | #8 |
08-22-2008, 10:56 PM | #9 | |
08-22-2008, 11:23 PM | #10 | ||
http://www.rccrawler.com/strongsteering.html im not worried about whether or not my servo (jr z9100t) can handle the added force my concern in the wasted energy Quote: | ||
08-23-2008, 01:25 PM | #11 |
RCC Addict Join Date: Jul 2008 Location: San Diego
| bent rod ends
This is what I did with the Traxas straight ends for steering. I Got aluminum rod at home depot,cut,drilled and tapped 3mm holes in them. Installed 3mm threaded metal rods. The pictures kinda show the way I filed 2 notches in the steering arm 110mm long-servo to knuckle 80mm long. I also had to file 1/16 off the diff to clear Good luck I hope this helps! |
08-23-2008, 02:20 PM | #12 |
Quarry Creeper Join Date: Jul 2008 Location: casa grande
I was wondering doe fileing the steering arm weaken it or is it not enough to do so.
08-23-2008, 03:04 PM | #13 |
There is alot of metal left. If it breaks I wil post it. The aluminum rods I use are thicker then the Axlial steering arms. The other thing is the steering also sits back a little more so it get hit as much. I'm an alignment and front end tech for Cadillac for 22 years and understand front end geometry. Matt |
09-06-2008, 04:35 PM | #14 | |
Rock Stacker Join Date: Aug 2008 Location: San Diego
Alex | |
