09-08-2008, 06:25 PM | #1 |
Pebble Pounder Join Date: Apr 2006 Location: Newton
| Too much flex
At first I thought it was a good thing, but now I can see that it greatly reduces my control. I'm hoping that someone on here could tell me some suggestions on how to control (correct) this. I"m running hot racing bent lower links front and rear four link mount on rear internal springs (med) Thick ass Lucus gear oil in the shocks The truck side hills and hill climbs really well, the problem is that as soon as things get technical, it flexes out to the point that all control is gone. I don't wanna go droop because I want my clearance. My wife is running full droop with 35wt and it controls very nicely though. What can I do? |
09-08-2008, 06:53 PM | #2 |
RCC Addict Join Date: Jun 2008 Location: Fresno
try a four link set up in the front and rear. the set up will help reduce ur articulatin making your suspension much more predictable |
09-08-2008, 06:57 PM | #3 |
thanks, i was even thinking about making some limitation straps to put a stop to the excessive wheel travel. (look super bad ass too) Anybody on here make them to sell?
09-08-2008, 07:02 PM | #4 |
Rock Crawler Join Date: Dec 2007 Location: 10 a see
You could also try shorter shocks, like T-Maxx. Thats what I use.
09-08-2008, 07:08 PM | #5 |
Quarry Creeper Join Date: Jul 2008 Location: Over a rock and under a bridge
Add a spacer on the shock shaft and limit the amount of articulation. I would add it on the inside of the shock body, but you like your current ride height, so that won't do. You'll have to add the spacer on the outside of the shock. Or, drive your wife's crawler and give yours to her. |
09-08-2008, 07:13 PM | #6 |
Newbie Join Date: Jul 2008 Location: Evansville
I've got the bump stops inside the shock bodies to get the ride height and fuel tubing on the outside to limit travel. Easy, cheap, and tunable.
09-08-2008, 07:26 PM | #7 |
I've got the bump stops inside already. It seems to me that the hot racing links actually rotate and that provides even more travel. I've also moved my links inboard. I'm just a victim of overkill i guess. And as for trading my wife. She says no, She is the driver and mechanic of her rig as well. Here are some pics of the excessive travel |
09-08-2008, 07:46 PM | #8 |
| HOLY ARTICULATION BAT-MAN!!!Is 90 degrees really enough? HAHAHA!
09-08-2008, 07:48 PM | #9 |
Rock Crawler Join Date: Jan 2008 Location: Arlington, TN
Fuel tubbing works great, cut a few peices at different lengths and pic the one that gives you the travel you are looking for |
09-08-2008, 07:50 PM | #10 |
Quarry Creeper Join Date: Dec 2005 Location: Tacoma
use some fuel line and put it on the shock shaft , at the bottom of the shaft where it mounts to the axle...that will limit the amount of travel you have...
09-08-2008, 09:24 PM | #11 | |
Quarry Creeper Join Date: Nov 2007 Location: Lakewood-Crawlerado
I would also put much stiffer internal springs in, you can probably find springs at your local hardware store; think it out, experiment a little, I'm sure you will find something Last edited by stublet; 09-08-2008 at 09:28 PM. | |
09-08-2008, 09:49 PM | #12 | |
09-08-2008, 10:51 PM | #13 |
Newbie Join Date: Aug 2008 Location: lewisville
(i dont think thats his truck, just an example) i made limiting straps from com tiny steel cable and crimps from lowes. tie em from the center upper cassis support to the link plate and your axle will only travel down that far then the weight of the rig will fall to what ever tire is in the air and you have weight on the tire that needs traction. |
09-09-2008, 05:13 AM | #14 |
Nope, that's my rig
