09-10-2008, 06:44 AM | #1 |
Newbie Join Date: Sep 2008 Location: Sydney
| Two Problems?
I just installed the bent links and i notice they seem to sit lent over and not stright up and down.. now doing this One. the tires hit them and seem to grab when at full lock either way Two and full flex up the links faul on the base of the shock the spring seat.. are they meant to do that and how do i fix the tires from not hitting? thanks mitch |
09-10-2008, 08:02 AM | #2 |
Rock Crawler Join Date: Apr 2008 Location: Lexington
How tight are your rod ends secured on there? If they are tight enough the links should have very minimal side to side play.. and shouldn't "fall" at all..
09-10-2008, 03:59 PM | #3 |
| Yer mate i looked at that after posting and tightened them up and did limit the move moment but still does the same thing... even if i put the standard plastic links it the tires still rub and bit in to the links..
09-10-2008, 04:38 PM | #4 |
Quarry Creeper Join Date: Jul 2008 Location: Galt
Swap the position of the shocks and the links on the axle so that the links are inboard, and the shocks are outboard. The bent links will then lay inwards.
