09-15-2008, 04:15 PM | #1 |
Quarry Creeper Join Date: Aug 2008 Location: Nashville
| My DIY Driveshafts
I got tired of the stock Axial shafts popping and spinning off...yeah I know...they make shafts...but I like the process of making my own parts. It took about 2 hours to get the basic functional shafts mocked up and ready to test...here is how I did it. Supplies & Tools Stick of round 3/8" inner diameter steel Stick of round 3/8" inner diameter steel 2.5" piece of spline steel Drill 1/16" Steel drill bit 1/8" long Set screw (I used a metric 3) Grind/cut off wheel Step 1 Cut your notches into one of of the square tube, then cut it to apprx. 1 inch. Once you have the notches cut, go ahead and drill the holes for the joint connection. Step 2 Take your piece of spline steel and drive it into your new square joint until it reaches the end where your tabs are..then go ahead and attach the swivel joint. Step 3 Notch the circle piece of steel in the same fashion as you did the square one...then cut it to around 2 1/4 inches. Go ahead and drill your holes into the tabs and attach the swivel joint. Now at the end of your new piece, drill the hole that you will use for your guide screw (use your 1/16" bit). Go ahead and tap for your screw and screw the guide screw in. Step 4 This step is easy....just stick it on your rig...and test it for fitting and clearance! I hope this helps someone out there!! You can also round the square tubing off with your grinder if you are worried about it sticking to rocks. Here is a small link to a vid showing movement.... http://s511.photobucket.com/albums/s...rrent=axle.flv |
09-15-2008, 04:19 PM | #2 |
Pebble Pounder Join Date: Aug 2008 Location: San Jose
Cool, They look like they can take a beating, haha. Myn are already starting to become a little warn. Any ways, great JOB! looks great. |
09-15-2008, 04:21 PM | #3 |
09-15-2008, 04:49 PM | #4 |
Quarry Creeper Join Date: Jul 2008 Location: Galt
Interesting DIY. I hope that guide screw is strong enough to withstand all of the torque being transferred from the outer tube to the splined tube. How much did it all cost you?
09-15-2008, 05:21 PM | #5 |
| It has thus far...over 2 hours of testing and it's holding strong. It cost around $20 for everything...but I have enough material to do 10 or so shafts out of the tubing!
09-15-2008, 06:41 PM | #6 |
Why not use the round on both ends instead of the square on one end? Instead of a guide screw in that end, you could just use a small screw as a pin to keep them from spinning. Just a thought. I like it. Creative. |
09-15-2008, 06:44 PM | #7 |
| I actually have one like that I'm doing now...great minds think alike...lol! Thanks for the comments!
09-15-2008, 08:19 PM | #8 |
RCC Addict Join Date: Oct 2007 Location: Kennewick, Washington
This "spline steel" .....kind of looks like a "roll pin", would that be correct?
09-15-2008, 09:33 PM | #9 |
RCC Addict Join Date: Jul 2008 Location: San Diego
great Idea! Can I suggest maybe 2 or 3 screws in the slot. I think thats the weakest link. great job. I like your 4 link suspension! How is that working? Matt |
09-16-2008, 07:30 AM | #10 |
09-16-2008, 07:32 AM | #11 |
| Great idea! The four link is doing killer...just been messing with different rod lengths to get the right clocking on the axle. Once I have it set where I want it, I'm going to fab up something! Thanks for the comments!
09-16-2008, 07:31 PM | #12 |
Rock Stacker Join Date: Aug 2008 Location: Lexington
i was at work today and thought about this drive shaft and something i seen on xtreme 4x4 they made their own drive shaft and the used tube like you did but with out the pipe they had two diffrent size tube steel one slide into the other and it didnt need a guide pin and you could make the yokes just like you did on both sides
09-16-2008, 08:05 PM | #13 |
In the 1:1 world many front drive lines are made of sqaure tubes that slide into each other.They are very strong but normaly have a LOT of run out and wear bearings out fast in the transfer case and pinion. This will eventually have the same effect , but it is cheap and creative.
09-17-2008, 12:02 AM | #14 | |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
Its a good idea but with the many variates of materials out there and the "small in size" we have to deal with, you could have built a more sound unit. Oh and integy makes steel drive lines for 30 bucks a set. | |
09-17-2008, 12:11 AM | #15 |
I wanna be Dave Join Date: Jun 2005 Location: drillin Holes for the man
I would suggest using key stock for the male shaft. get a piece that fits in the square tube. It will be like 1:1 using reciever hitch stock for there front drive shafts that way! nice idea though Last edited by bigflex; 09-19-2008 at 09:09 AM. |
