09-21-2008, 08:36 AM | #1 |
Newbie Join Date: Sep 2008 Location: wichita
| 2 motors
has anyone tried to put two motors on an ax10? if so what was the result?
09-21-2008, 08:43 AM | #2 |
Rock Stacker Join Date: Aug 2008 Location: Chestnut Ridge
Where are you going to put the second one?
09-21-2008, 08:52 AM | #3 |
Quarry Creeper Join Date: Oct 2007 Location: PF, WI
I dont see why you would want to. It would add more unnecessary weight, and you can get all the torque you need out of a single motor.
09-21-2008, 09:19 AM | #4 |
right over the motor? the only problem i see is too much weight on that side.
09-21-2008, 09:34 AM | #5 |
Rock Crawler Join Date: Apr 2008 Location: Lexington
Seems pointless to me honestly. One motor is really all you're gonna need. The drawbacks are probably draining your battery a lot faster and added unnecessary weight. Why not just buy a better single motor? Not busting your chops, I just really think it's kinda pointless.
09-21-2008, 09:39 AM | #6 |
RCC Addict Join Date: Dec 2007 Location: Chuck Chuck Chuckin Rocks.
09-21-2008, 10:24 AM | #7 |
no i was planning on stacking the motors on one trans. with a custom motor plate.
09-21-2008, 12:34 PM | #8 |
One motor and two trannys would be more practical. Then you could have front and rear dig if you wanted. |
09-21-2008, 01:07 PM | #9 |
Debunking old stereotypes Join Date: Feb 2006 Location: 1st and Amistad
Why not buy a Berg and be done with it |
09-21-2008, 01:15 PM | #10 |
Pebble Pounder Join Date: Sep 2008 Location: Scotland Neck
09-21-2008, 03:48 PM | #11 |
I wanna be Dave Join Date: Oct 2005 Location: Columbia TN
Two trannys with two motors are even better......... The Wifes Pink Double Deuce |
09-21-2008, 06:15 PM | #12 | ||
Oh well. Quote:
JC | ||
09-21-2008, 08:42 PM | #13 |
yeah the one motor two trans does sound crazy. about the berg i dont realy like the motor on the axel. plus it is quiet a bit more pricey.
09-21-2008, 08:45 PM | #14 |
09-21-2008, 08:56 PM | #15 |
| Actually to build a set of Axial axles that hold up and compare to Bergs it is $250 +/- a few bucks. And still the MOA axles are still alot stronger. Hell the new Hot Racing MOA axles seem like a steel!
