09-24-2008, 02:40 AM | #1 |
Newbie Join Date: Aug 2008 Location: Assen
| Mine Axial Artr Build (the Netherlands)
Hello, Exuse me for mine bad english. (dutch) This is mine Artr build so far. The box: Novak GOAT BL set, met 18.5 BL crawler motor: I like aluminium, and Stainless steel. Lets get building: Shorten body post, and mounting them with some St.Steel Center drive shaft: Alu "Xray style" Battery plate holder: Mounted with St steel and alu/st. steel washers: Shimmed the axles, and put some st. steel fastening materials: Alu spurgear holder: Alu motorplate: With green spacers: Alu chassis plates with inner linkage mounting: Extra hole for motorplate: Too little room for the linkage,sanded , and problem solved. De center skid wheels: An tight fit: linkage an chassisplate: Alu gearbox cover!, st.steel outdrives, shimmed an greased: the transmission completed: an little sanding, on some places, and it will fit nicely: Hitec 5645 servo in alu servo holders: Alu 3 links: Me, and mine creative brain, and some parts: Well 3 hours of thinking to get all of it to fit nicely. Verry tight fit with the electronics: Trimmed the body Lipo time! Zippy 2s1p 1600mah lipo,between lexan plates: Side view: An littel mod for the power wires: All tight up securly,: To Be Continued.... Last edited by Psygho; 09-25-2008 at 01:22 AM. |
09-24-2008, 05:22 AM | #2 |
Pebble Pounder Join Date: Jul 2008 Location: Anderson
Looking good. I really didn't understand all of what you were saying. I like some of the ideas you came up with. A great start. But be carefull, that lady on your laptop is about to loose a eye if that puppy pops out of there... just a heads up. Jason |
09-24-2008, 05:37 AM | #3 |
Rock Stacker Join Date: Feb 2008 Location: Lincoln RI
I like to idea of the skid plate wheel. Thats the first time I've seen it done.
09-24-2008, 07:56 AM | #4 |
Quarry Creeper Join Date: Aug 2008 Location: Nashville
Looking good so far...the biggest thing next will be tires and weight. Go for the Panthers! Mess around with weight around the rim..inside the tire. You'll find a balance that works for you. I have 3/4 of a pound in my front and around 4 ounces in the rear tires. Also...move your lipo a bit lower if you can! Anxious to see more! |
09-24-2008, 06:05 PM | #5 |
Pebble Pounder Join Date: Apr 2006 Location: Newton
wow, lots of money in that one. I like it. Good work.
09-25-2008, 12:54 AM | #6 |
Thnx for the reply's! Iam running mine rig at mostly on partial loose sand, so i am wondering if it is an good idea to get alu axles and alu rims... The lady on the laptop is mine own wife, no problems there ;) Well it costs a bit money, but the money pitt, is hang above mine axial, and it is mijn Alu ford f350 hilift, almost everything is aftermarket! I have an complete build story on an other (dutch) forum, where i am an modarator. Dont know if it legal to post links to other forums, but here it is (it is in dutch, but have lots of pics, so that should not be an problem.) http://www.modelbouwforum.nl/forums/...07-2008-a.html Regards: Emil Last edited by Psygho; 09-25-2008 at 01:18 AM. |
09-25-2008, 02:52 AM | #7 |
I wanna be Dave Join Date: Sep 2005 Location: *
The AX10 looks great, you really go all out on the aftermarket parts...And your highlift is CRAZY...Nice work on both |
09-25-2008, 05:20 AM | #8 |
Rock Crawler Join Date: Aug 2008 Location: Strugglin
nice shelf queen
09-27-2008, 07:58 AM | #9 |
Newbie Join Date: Sep 2008 Location: canada
| very nice just got 2 put the electronic on upper links and the battery in the front ps the wheel skid is very cool |
09-27-2008, 09:17 AM | #10 |
Rock Crawler Join Date: Apr 2008 Location: Rancho Cucamonga
09-27-2008, 02:11 PM | #11 |
Quarry Creeper Join Date: Jul 2008 Location: Ventura, Ca
09-27-2008, 03:19 PM | #12 |
Pebble Pounder Join Date: Aug 2008 Location: Strafford Mo
Thats one nice build bud, watch the pins in those hot racing shafts, they like to fall out on you |
09-29-2008, 02:41 AM | #13 |
Yes, already had that problem. Bought an 0.89 MM allan wrench, and made me some custom spring steel pins, made (milled) an radial groove in the pins, rather then just an axial minor flat spot. Cost me about 2 euro, and half an hour work... Other solution, was, to made 2 radial groves, and put some c-clips on the ends, but i liked mine first idea the best, and it worked fine.... |
09-29-2008, 01:23 PM | #14 |
Rock Stacker Join Date: Oct 2007 Location: beaverton
beautiful truck...
