10-08-2008, 11:47 AM | #1 |
Quarry Creeper Join Date: Sep 2008 Location: centennial
| tell me what you think.
so i was thinking how would i make the tire pressure adjustable. eliminate taking apart the bead locks and trying to adjust it that way. i decided that putting some bike tire Presta(sp?) valves in to the rim its self might work as a regulater to take pressure out of the tire and possibly use it as a vent as well. i would like to know what you think. sorry about the pictures i had to take it with my phone this time. questions and criticism is welcome |
10-08-2008, 12:04 PM | #2 |
I wanna be Dave Join Date: Dec 2005 Location: Tax Nation
just a thought.... foam? the only reason I see for running a valve stem and air pressure would be if your running water/calcium chlorite in the tires. |
10-08-2008, 12:38 PM | #3 |
Rock Stacker Join Date: Aug 2005 Location: Findlay, Ohio
I've seen people try that before, just doesn't work well at this scale. modding your foams to a good all around set up is the best bet.
10-08-2008, 12:41 PM | #4 |
Rock Crawler Join Date: Aug 2008 Location: Strugglin
i must be missing something.can you explane why you dont want to run foams
10-08-2008, 02:33 PM | #5 |
Rock Stacker Join Date: Aug 2008 Location: Chestnut Ridge
Ok. Foam alone works better than air pressure. |
10-08-2008, 03:04 PM | #6 |
10-08-2008, 06:59 PM | #7 |
Rock Crawler Join Date: Jun 2008 Location: Clinton,Michigan
nice laptop i got the same lol |
10-08-2008, 09:49 PM | #8 |
Rock Stacker Join Date: Sep 2005 Location: lakeland
wow must be a good lap top cuz im on mine now just like it. any of yal running vista on yours or just xp still?
10-08-2008, 10:51 PM | #9 |
Pebble Pounder Join Date: Aug 2008 Location: San Jose
nice rig, looking good |
10-08-2008, 11:06 PM | #10 |
seems like a lot of work for a little benifit, if any. just run some decent memory foams.
10-08-2008, 11:13 PM | #11 |
Pebble Pounder Join Date: Oct 2007 Location: murphys
I like that, thats thinkin out side the box. I always hated running foams with a hole in the tire, foams get all nasty as **** and stinky as **** too. And real trucks dont run foams. Good job |
10-08-2008, 11:20 PM | #12 |
Rock Stacker Join Date: Apr 2008 Location: Vienna
hi! one question: how about the tire-balance, if you apply the valve as weight at a certain point to the wheel? doesn't it wobble at high-speed? sincerly tomancik |
10-08-2008, 11:26 PM | #13 |
10-08-2008, 11:27 PM | #14 |
10-08-2008, 11:29 PM | #15 |
10-08-2008, 11:31 PM | #16 |
| thanks im thinking about taking the foam out and finding a way to seal the valve because it seems like the air sneeks back in.
10-08-2008, 11:33 PM | #17 |
| im not to worried about speed at all i have a 55t motor in it so it not that fast at all. and nor will i probably put a faster one in it. it has some wobble i mean the 9 oz. of weights in each tire throws it a little bit and those bead locks are hard to get to go straight
10-08-2008, 11:35 PM | #18 |
as for memory foams i like Aces donuts from RCP crawlers. ive also heard that the NWTractech foams are nice as well. theyre available in the vendors section here on rcc.
10-08-2008, 11:44 PM | #19 |
10-11-2008, 10:13 PM | #20 |
Quarry Creeper Join Date: Mar 2008 Location: Huntington Beach
thats a good idea. Nice rig, you got a lot of articulation in it.
