10-09-2008, 01:03 AM | #1 |
Rock Stacker Join Date: Jul 2008 Location: clovis
| My rtr with titanium shock mounts
This is my first cr crawler. started with a rtr, couldnt get a artr and wanted to be able to drive it that knight. Radio is a mx-3 stock esc and motor hitec hs645mg servo made my own lower links with brass rod but will turn some out of ti soon battery tray on rear axel I put losi 4 in shocks and made some titanium mounts to get the ride to about 2.75in at the skidplate. any feed back would be appreciated. here is some pics of the overkill head lite |
10-09-2008, 01:15 AM | #2 |
Rock Crawler Join Date: Feb 2007 Location: wahiawa
that's a bright light....that calls for moonlight crawl.. |
10-09-2008, 01:16 AM | #3 |
Newbie Join Date: Jun 2008 Location: kona
wow what are you useing for the headlights? must be good for some night crawling nice chop job on the body, and keep up the good work
10-09-2008, 01:21 AM | #4 |
Quarry Creeper Join Date: Mar 2008 Location: Hilo
May want to move the battery to the front axle. And damn thats some light |
10-09-2008, 01:26 AM | #5 |
thanks the lite is a cree led with a driver that gives it high low and strobe. it puts out over 200 lumen. you can buy some cool stuff from dealextreem http://www.dealextreme.com/details.dx/sku.11022 |
10-09-2008, 01:29 AM | #6 |
10-09-2008, 01:35 AM | #7 |
Rock Stacker Join Date: Sep 2008 Location: Manchester, New Hampshire!
Killer Set up man looks great The Head lights look intense.. Bet makes it alot of fun crawling at night!. And for the battery. Move the saddle pack's to the front axel.. And yes there the C packs. Keep it up looks awesome! Last edited by Ax10CrawlNH; 10-09-2008 at 01:38 AM. |
10-09-2008, 08:46 AM | #8 |
Quarry Creeper Join Date: Oct 2007 Location: Toronto, ON. Canada
to have a 6-8 cell saddle pack configuration on the axles. you need the 2/3A size batteries. others have done the SUB-C in their own configuration. but the norm is 2/3A. |
10-09-2008, 06:59 PM | #9 | |
Rock Crawler Join Date: Jun 2008 Location: Clinton,Michigan
10-09-2008, 09:05 PM | #10 | |
"to have a 6-8 cell saddle pack configuration on the axles. you need the 2/3A size batteries. others have done the SUB-C in their own configuration. but the norm is 2/3A. " what are the runtimes compared to these reedy 3600s I have now? Im going to make a servo plate that will hold the servo on its edge and centerd on the axel so i can use these batterys. "Killer Set up man looks great The Head lights look intense.. Bet makes it alot of fun crawling at night!. And for the battery. Move the saddle pack's to the front axel.. And yes there the C packs. Keep it up looks awesome! " thanks | |
10-10-2008, 04:33 PM | #11 |
I made a mount for the servo to stand up on the center of the front axel. this gives enough room to put those big batterys up front. I have to much weight in the front tires from trying to make up for the batteys on the back. ill remove some tonight and and see how it works. |
10-10-2008, 05:41 PM | #12 |
Newbie Join Date: Aug 2008 Location: british columbia,canada
are those stock axial shocks? if so how do you like runnin em upside own? any major difference
10-10-2008, 06:26 PM | #13 |
no there 4 in losi. tso much better then the stock ones |
10-10-2008, 07:39 PM | #14 |
nice job on the servo mount, you made the sub c's fit perfect up there |
10-10-2008, 08:38 PM | #15 |
Quarry Creeper Join Date: Jun 2008 Location: Hell
those arn't sub c's just c's. |
10-14-2008, 11:01 PM | #16 |
I did some more to it. I cut the skid plate and moved lower links inside the chassis side plates. drilled new holes in the side plates for the upper links and added a cup and ball to the origanol plastic links. this made a big diferance in torque twist. |
10-14-2008, 11:26 PM | #17 |
Quarry Creeper Join Date: Sep 2008 Location: Rocklin
Nice Pics! I like what you did with the front servo Looks Awsome.
