10-11-2008, 11:05 PM | #21 |
Quarry Creeper Join Date: May 2008 Location: looking for sponsors
1.5???
10-11-2008, 11:05 PM | #22 |
Quarry Creeper Join Date: Jul 2008 Location: looking for that perfect setup
ya thats wat i said
10-11-2008, 11:18 PM | #23 |
I wanna be Dave Join Date: Jun 2005 Location: drillin Holes for the man
try these in the rear! http://www.horizonhobby.com/Products...rodID=LOSA5148 |
10-11-2008, 11:20 PM | #24 |
ok are you running the Losi crawler shocks? also what chassis are you running?
10-11-2008, 11:20 PM | #25 |
1.5 is way to low!
10-11-2008, 11:26 PM | #26 |
yes losi 4" set and stalk ax 10 chassis but i have a bender swx on order |
10-11-2008, 11:30 PM | #27 |
are your adjusters turned down far enough to extend the shafts all the way when sitting under its own weight? You could always get some heavy duty dubro rod ends. They are alot longer and would lift your belly up a bit. I had to do that on my sons GC1.
10-11-2008, 11:33 PM | #28 |
i think that the ajutable nut on it would do the trik no? |
10-11-2008, 11:39 PM | #29 | |
i dont get wat ur saying? | |
10-11-2008, 11:48 PM | #30 |
ok if you have Losi crawler shocks they have threaded bodies and the upper spring perch is also threaded and adjusts up and down on the shock body. The losi shocks need to have the adjusters run almost all the way down to extend the shock shaft all the way out. Otherwise they will be running semi droop. As far as the rod ends go the dubro rod ends are long and lengthen the eye to eye length of a shock a little over a 1/4". Does that make better sence? Sometimes I forget that not everyone has been in this as long as I have.
10-11-2008, 11:51 PM | #31 |
yes so i am running semi droop? and the nut will work |
10-11-2008, 11:55 PM | #32 |
more than likely. Were are the perchs on the shocks? Almost all the way to the top? middle? When you pick up the rig will the shocks drop out some?
10-12-2008, 12:01 AM | #33 |
oh yes it will drop alot
10-12-2008, 12:04 AM | #34 |
10-12-2008, 12:05 AM | #35 |
ok kool
