10-17-2008, 04:19 PM | #1 |
Newbie Join Date: Sep 2008 Location: Waipahu
| CKRC Stage 2 w/ Novak brushless ?
I have installed the CKRC Stage 2 mod but have one problem. The upper rod ends all bolt up to the new holes in the chassis but one. The upper link that attaches next to the motor hits the motor & there is not enough room to even put the nut on. Im running a Novak brushless motor & cant install the last upper rod end. Has any one else had this same problem? What do I need to do? Do I need to go back the stock holes in the front, or does this mod work only with brushed motors. Any advice is appreciated. Thank You!
10-17-2008, 05:42 PM | #2 |
no talent hack Join Date: Feb 2007 Location: Redwood City
what if you put the screw through the inside, and the nut on the outside?
