10-19-2008, 06:40 AM | #1 |
Pebble Pounder Join Date: Sep 2008 Location: bel air
| free suspension mod
As everyone knows the stock springs on the axial are very stiff. On my artr I took the spring retaners off the bottom of the shocks and it works very well. The trucks links are now level with ground but the shocks can still extend for flex. This mod also softens the suspension alot. I like this mod and it is also free, try it for yourself
10-19-2008, 07:01 AM | #2 |
Rock Crawler Join Date: Aug 2008 Location: Strugglin
i really think you will change this back after awhile.if i were to do this on my crawler it would just add more torque twist. the spring is still as stiff as it was. the mod would add alot of slop in the springs and would not be smooth at all. i dont think this is the way you want to lower your ride height just my 2 cents
10-19-2008, 09:21 AM | #3 | |
RCC Addict Join Date: Jun 2008 Location: Fresno
and as everyone knows, its really whats on the outside that counts | |
10-19-2008, 10:38 AM | #4 | |
Rock Crawler Join Date: Aug 2008 Location: Alamogordo
10-19-2008, 10:38 AM | #5 |
Rock Crawler Join Date: Feb 2005 Location: Oxford, MA
I don't run any spring spacers on my stock shocks either. |
10-19-2008, 11:47 AM | #6 |
Rock Crawler Join Date: Sep 2008 Location: estacada
if you like that setup, you might try eliminating the outside spring ang going to your local hardware store get a couple of small springs that would fit on the inside of the shock body and play around with that, it cheap. i.e. droop or part droop.
10-19-2008, 01:45 PM | #7 |
RCC Addict Join Date: Jan 2007 Location: San Jose
more torque twist, and too much slop in shock plus less control when shocks unloads.
10-19-2008, 02:02 PM | #8 |
RCC Addict Join Date: Dec 2007 Location: Moncton, NB, Canada
| Not sure how good it would work on the AX10, but I've read of people doing scale stuff using the springs from pens inside the shocks and it working pretty good.
10-19-2008, 02:20 PM | #9 |
RCC Addict Join Date: Mar 2005 Location: Saginaw
| He's not talking about pre-load spacers. He means the retaining cups that sit above the ball-end, at the end of the shaft... ...which I wouldn't recommend, really. Those retaining cups hold the spring in place. I would snip a few coils off the springs before I ran the shocks without the retainers. |
10-20-2008, 06:01 PM | #10 |
To reduce my torque twist i put a preload spacer in the left rear shock still with out the spring retainer and it works pretty good.
10-20-2008, 06:10 PM | #11 |
Newbie Join Date: Jul 2008 Location: no. cal bay area east county
I eliminated my twist by going with the tcs 4 link plates and moving my lower links inboard with home made delrin skid,droop front, sprung rear with medium internal springs ....works great.
10-20-2008, 10:11 PM | #12 |
Quarry Creeper Join Date: Sep 2008 Location: centennial
10-21-2008, 01:53 AM | #13 |
| people do this and change oil too, put higher number in, which is only a temp fix. link geometry and motor placement i think contribute a lot. |
