10-29-2008, 08:46 PM | #1 |
Newbie Join Date: Oct 2008 Location: heavener,ok
| bc/axial swx chassis help
for all of u that have a swx chassis could yall tell me or post a pic would be better of the body post location idk were to put the posts to mount the body ...... And would the ckrc's dig fit the servo mount is going to be close to the chassis side any sugestions of making a custom servo mount for the dig...
11-04-2008, 04:54 PM | #2 |
Newbie Join Date: Nov 2008 Location: Maitland
Hope this helps, I have a dna dig but it all fits! Last edited by rickyax10; 11-04-2008 at 05:20 PM. |
11-06-2008, 12:55 PM | #3 |
Quarry Creeper Join Date: May 2008 Location: So-Cal
I really like this chassis but have not got the gutts to attempt to get a dig in there. Looks really compact as it is before dig. Not too difficult though?
11-06-2008, 01:20 PM | #4 |
Quarry Creeper Join Date: Mar 2008 Location: richmond
the dig will fit with the servo on top! i just had to dremel a little off the top edge to get the servo arm to clear.between the WX
11-06-2008, 01:30 PM | #5 |
Pebble Pounder Join Date: Oct 2007 Location: Bay Area
You can mount the servo lower in the chassis by bolting the dna servo mount to the top upper link hole on the open side of the chassis. To keep it from rocking I used a post going from the servo mount to the skid plate and have a screw coming through the skid plate securing it. My upper links cleared everything but I am also using 4-link mounts not the stock 3-link.
11-07-2008, 06:41 AM | #6 |
thanks guy big help ... The swx chassis is sweet
11-07-2008, 08:09 AM | #7 |
I wanna be Dave Join Date: Aug 2008 Location: Deep in Swing Town
top mounts... only way to go wont hang up..... |
11-07-2008, 08:40 AM | #8 |
I have a problem the drive shaft touching the skip plate I'm useing losi 4 shocks put them in the first hole with the spacer on the 3 link and I put the spacers on the lower links with no spacers in front lowers or the uppers I did it jest like the paper said but with losi shocks and the drive shaft touches the skip ........?
11-07-2008, 08:53 AM | #9 | |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
11-07-2008, 11:05 AM | #10 |
All right but I see u are runing the big spacer in the front and non in the rear on the upper 3 links
11-07-2008, 12:28 PM | #11 |
Looking at the downloaded manual the front should have a 1mm spacer between the 3 link and the mount on the axle and the rear should have a 4mm spacer between the 3 link and the mount on the axle. Image 6 on the downloaded manual in my opinion should say "Front" not "Rear". The rear is already taken care of in image 3. |
11-07-2008, 02:00 PM | #12 |
all right thanks man I got it all good to go now I'm jest wating on vf to make there digs idk I might go and buy the regular DNA dig off rcp.com
