10-30-2008, 06:54 PM | #1 |
Rock Stacker Join Date: Oct 2008 Location: somerset va.
| new toy
i'm getting the artr in a few days and i have the novak rooster with the 55t motor and 1500 mah battery and a digital am radio with a cirrus cds751 steering servo. i'm new to crawling and would like to get the best i can from this setup. this will be just for play and no comps. any tips or things i can do to make it better would be great thanks.
10-30-2008, 07:03 PM | #2 |
Newbie Join Date: Oct 2008 Location: Stockton
Best mod is free, put batteries on front axle
10-30-2008, 07:10 PM | #3 |
Newbie Join Date: Sep 2008 Location: Melbourne Australia
add weight to the wheels star cut the foams inboard the links if you look in the tech section there is a great piece on improving the standard ax10. good luck with it |
10-30-2008, 07:19 PM | #4 |
Rock Stacker Join Date: Aug 2008 Location: Lincoln
Turn your shocks upside down for a lower CG. Mount your ESC and Rx on the upper links, also helps with lower CG and help keeps them out of harms way in a roll over.
10-31-2008, 05:16 AM | #5 |
thanks for the tips. how do i inboard the links?. |
10-31-2008, 06:17 AM | #6 |
Newbie Join Date: Jan 2007 Location: Harrisonburg
Search for Mirror Tranny. It is free and will help with the torque twist a little. I would also 4 link the front and back. And like someone else said, the battery over the front axle will help alot. Buy a split pack, it is a great investment.
10-31-2008, 07:04 AM | #7 |
Quarry Creeper Join Date: Oct 2008 Location: Southern Illinois
If the ARTR comes with memory foams, do you still have to star cut them?
10-31-2008, 07:42 AM | #8 |
Rock Stacker Join Date: Sep 2008 Location: gj
panther couger tires and memory foam inserts and you never need to cut mem foams they take place of the star cut that is suggested |
10-31-2008, 08:00 AM | #9 |
Pebble Pounder Join Date: Aug 2008 Location: San Jose
10-31-2008, 08:23 AM | #10 |
RCC Addict Join Date: Jun 2008 Location: Fresno
10-31-2008, 08:45 AM | #11 |
Rock Crawler Join Date: Aug 2007 Location: Casper, WY
If you're not planning to compete (even if you are), stick with the stock Hammer tires w/ memory foam. I'm running mine with 5oz of lead in the front and none in the rear. They're good tires. And like others have said, do not star cut memory foam.
10-31-2008, 10:12 AM | #12 |
Quarry Creeper Join Date: Jul 2008 Location: Galt
Add wheel weights, install softer springs (except for the left rear, or preload the left rear with spacers), limit the shock travel by installing 1/4"-1/2" spacers inside the shocks (you'll need to pull the shaft out of the shocks to do this), reconfigure your battery to fit on the front axle or get a NiMH saddle pack. BTW, if you want to flip the shocks upside down, you will need to buy new 3x30 hex screws to allow you to move the links inboard of the inner mounting tabs on the axle to get enough clearance to not bind the shock caps against the links. |
10-31-2008, 07:46 PM | #13 |
great help guys thanks. all i need now is it to show up lol.
10-31-2008, 11:01 PM | #14 |
| have a look in the tech section at the CKRCCrawlers link on how to prep an AX10 for comps.Between the text and the photos its pretty easy to do. I have the rtr it came with standard foams which need cutting so if those with experiance say dont cut memory foams than who am I to disagree |
11-02-2008, 06:42 PM | #15 |
ok i found a few mods i'll be doing and some parts i'll be ordering lol. less than 48hrs and i'll have my truck lol. yup i don't even have it yet and i'm buying parts for it so much for me thinking this was going to be cheaper than 1/8 scale nitro.
11-04-2008, 06:03 PM | #16 |
well i got it today and have all electronics installed and running. need to do a few tweaks but so far so good the cats hate it.
11-04-2008, 06:17 PM | #17 |
Rock Stacker Join Date: May 2008 Location: The great U.P. (Northern Michigan)
I am in pretty much the same boat as you, bought the ARTR, electronics, and am just using it around here, there's no comps here so i don't need a comp rig, the #1 upgrade that you make, would be to buy a split pack and put it on the front axle, i ran mine stock with the battery up top, and i had all my electronics on the upper links, it was fun...... but pretty roll over prone, then i bought two 8 cell split battery packs, and wow, did it make a huge difference. I was driving around today, playing with some tires i got off a 2wd truck of mine, put in the old pack, then got bored of that and put on the split pack (was trying to save the split back for the day but couldn't resist) and the increase in speed was noticable and as stated above as was the performance, trust me, split packs in my opinion is a GREAT choice to go with. I also upgraded to front and rear 4-link which aided in reducing the torque twist.
11-04-2008, 06:36 PM | #18 |
i have 2 saddle packs on the way along with mounting plates,aluminum shocks,3 different sets springs and roller's for the skidplate. i plan on doing the inboard links also. we'll see how it does with these mods for now and go from there.
11-04-2008, 07:57 PM | #19 |
Newbie Join Date: Sep 2007 Location: channahon
put a piece of fuel tubbing in the shocks, befor the piston on the shaft to make them shorter so that it sits lower, softer springs with thicker fluid
11-04-2008, 08:02 PM | #20 |
ok i have softer springs on the way and i'll check out the fuel tubbing trick. here it is in stock form (but not for long lol) |
