11-16-2008, 10:39 PM | #1 |
Quarry Creeper Join Date: Sep 2008 Location: Rocklin
| Fine tuned Custom AX10
Check out these vids of my custom tube chassis i Built that use AX10 parts. Enjoy the vids tell me what you think will get pics on here soon of build. http://vids.myspace.com/index.cfm?fu...deoID=46623015 Last edited by Robbs2001tj; 01-15-2009 at 09:08 PM. |
11-16-2008, 11:04 PM | #2 |
Quarry Creeper Join Date: Sep 2008 Location: centennial
thats sweet do you have a lot of weight in your tires? nice rig |
11-16-2008, 11:21 PM | #3 |
I am running the Losi Claws with about 7 oz of lead in each wheel on the fronts. about 3.5 oz of lead in the rear tires. i am running custom 7 cell saddle pac I made up last night with 2/3a 1600ma cells.
11-16-2008, 11:25 PM | #4 |
sweet how much did that bat set up run ya i need to so saddle packs, how long does that last in running a 3300 6 cell and i get a lot of time and quite a bit of power in having a tough time giving that up |
11-16-2008, 11:35 PM | #5 |
After hard crawling today it seems to last about 40 mins. I am running alot of goods though. the only down fall is that you can only charge them at 1.5 amps or lower so it takes a while to charge them. they are cheap to about $23.00 for each pack. I am running a novack goat bushless system w a high tech 7955 tg coreless steering servo and a 225mg mini servo for my dig
11-16-2008, 11:38 PM | #6 |
you can by the packs already built at max amps or cheaper battery packs .com they run in the $27.00 range and they are only 1500 ma. my charger puts about 1750 ma into my 1600ma packs.
11-17-2008, 12:19 AM | #7 |
Pebble Pounder Join Date: Oct 2008 Location: Santa Rosa
Looks good! What is the total weight of your rig?
11-17-2008, 12:21 AM | #8 |
11-17-2008, 08:31 PM | #9 |
Here is another vid and some pics http://vids.myspace.com/index.cfm?fu...deoID=46625903 http://i435.photobucket.com/albums/q...Picture405.jpg http://i435.photobucket.com/albums/q...Picture396.jpg http://i435.photobucket.com/albums/q...Picture443.jpg http://i435.photobucket.com/albums/q...Picture444.jpg |
11-17-2008, 08:34 PM | #10 |
11-21-2008, 08:58 AM | #11 |
12-05-2008, 07:03 PM | #12 |
Newbie Join Date: Apr 2008 Location: Frederick
Kool rig.What did you use for tubing?
12-05-2008, 08:24 PM | #13 |
Newbie Join Date: Nov 2008 Location: GROVE CITY
very nice, I noticed your lower links are mounted towards the outside of your axles. Have you tried them closer to the diff? what way works best for you?
12-18-2008, 08:04 PM | #14 |
12-18-2008, 08:12 PM | #15 |
| had the lower links all the way to the inside had too much torque twist. now with the links to the outside i can punch it and it takes off straight as an arrow.
01-15-2009, 09:04 PM | #16 |
01-16-2009, 12:31 AM | #17 |
| Thanks for the complement! It has taken a while to get it there but I am finally satisfied with it. I also see that you guys are making thread shock bodies for the axial. How are they working out? I am still using the stock ones but want to upgrade to the aluminum ones. |
01-16-2009, 07:43 PM | #18 |
also I am in progess of getting the build up on here will have it on here in a couple days!
