11-28-2008, 04:02 PM | #1 |
WWW.THEROXBOX.COM Join Date: Sep 2007 Location: The Legend of Stone Pillow
| HBZ WartHog "Tuber Chassis" STAGE 3 HBZ WartHog "Tuber Chassis" STAGE 3 Well The more i drive this rig the more little thinks I find, So here are a few update to this rig. I started to pull in my lower links,,,,, but i quickly ran into a hieght problem. with my DNA dig and Cobalt 10t hanging out my links get hit.... I laser cut a new thicker skid plate to allow the lower links to move more freely when pulled in, but that would raise my dig unit into a cross brace of my rig. Which would stop the movement of the servo arm. So i left my links on the out side.. HELP ........ now if someone has been able to but in a DNA dig, Cobalt 10t and brought in their lower links, please let me know or even post up a picture. Thanks in advance |
11-28-2008, 04:09 PM | #2 |
I added berg shock, this helped me get my ground clearance under my skid plate the 3" i was looking for .... the axial shocks could only get me 2 3/4" I also moved my ESC to my rear axle by using my old servo plate ... I also moved my RX down onto my front links.....:-P |
11-28-2008, 04:11 PM | #3 |
I was able to clean out my whole inside of the chassis..... no weight other than the motor and tranny.. |
11-28-2008, 04:14 PM | #4 |
After changing my shocks and using thicker spacers i was able to get more movment out of my rig .... a huge differance
11-28-2008, 04:24 PM | #5 |
Well sence i could not bring in my lower links, i thought i would cover the links to help keep them from getting caught on the rocks. Note: sence these pictures i have added buttom cap screws, and now it is totaly smooth down the side ..... I realy like this truck ... |
11-28-2008, 04:26 PM | #6 |
Rock Stacker Join Date: Oct 2008 Location: enfield
hi nice warthog . I got a Question where is my gmade zero shocks and 35t motor i ordered from u on Tuesday i got no shipping info u guy r usually grate on fast service travis
11-28-2008, 04:55 PM | #7 |
Pebble Pounder Join Date: Jul 2008 Location: bedrock
i used a double triangulated delrin skid from yotachump,custom solid stainless rear links drilled to 8 32,with jato rod ends,and to get my rear height back i used losi 4'' shocks with savage shock ends,still wasnt enough so i mad a small bracket on the 3 rear shock holes with 1/16 ALUMINUM AND ,drilled a hole lower on it to raise it about 1/4 inch higher,now it sits level, crawls exellent ,doesent bind at all |
11-28-2008, 05:01 PM | #8 |
Got any pictures of your set up.... Thanks for the info |
11-28-2008, 05:05 PM | #9 |
Rock Crawler Join Date: Aug 2008 Location: Strugglin
Yup she's bad ass |
11-28-2008, 05:08 PM | #10 |
Thanks the eye for the quick reply. I was hopping to bust some ones ass :-P RPP HOBBY is a great shop and i will use them ass often as i can. |
11-28-2008, 05:27 PM | #11 |
12-05-2008, 06:45 PM | #12 |
Newbie Join Date: Apr 2008 Location: Frederick
I like the rig and how well do they really work? i would like to know before i get one.
12-05-2008, 08:37 PM | #13 |
Colt Python/SR9c Join Date: Feb 2004 Location: out in the shop, reloading ammo!
I would suggest changing your lower links. You have the lowers and the uppers both coming "in" on the axle, which is not a good thing. You need to try and move your lower links on the axle, out more towards the wheels to triangulate your suspension. I would suggest moving them to the other side of the shocks.
12-05-2008, 11:45 PM | #14 | |
I wanna be Dave Join Date: Nov 2008 Location: Where freedom is earned.
Basically, since you moved the lowers outward at the chassis, you need to move them out at the axle as well. | |
12-06-2008, 10:10 AM | #15 |
Thank You |
12-21-2008, 12:13 PM | #16 |
Rock Crawler Join Date: Mar 2006 Location: Up North
Will that not mess with his steering angle!!! if both links are running outside of the Axle???
12-21-2008, 08:35 PM | #17 |
Rock Stacker Join Date: Mar 2008 Location: cedar park TEXAS
this may work may not but u could take the stock skid plate and cut out the mounting holes in the shape they are in and use it as a spacer on top of the skid u have now and that may give u ebough clearance.
12-21-2008, 09:35 PM | #18 |
Quarry Creeper Join Date: Apr 2007 Location: Harrisville, UT
for moving the lower links in on the skid, try making a new servo mount behind the dig, then you should be able to lift the trans a bit and move your links in. I've got the same skid and it's the only thing I don't like about it |
