| | #1 |
| Pebble Pounder Join Date: Dec 2008 Location: Victoria, BC
| Howdy. Bought an RTR last Sunday, already added the aluminum links and softer springs up front, weighted the wheels, etc, but I've discovered that the stock motor is way too fast I am intending on picking up a 55T motor (Axial, Integy, whatever) to slow her down and hopefully gain some control, and I really need to upgrade the servo (thinking Hitec 645 MG). I have noticed that if the front end is bound up, and I try to turn the wheels, nothing works - is this a case where the servo is 'stealing' all the power from the receiver, leaving nothing for the motor? Will this happen with the Hitec servo too? Will the addition of a BEC fix this? Thank you and good day. PS: I will eventually upgrade the whole slew of electronics - I'm just trying to do this in as logical a fashion as possible. |
| Sponsored Links | |
| | #2 |
| Quarry Creeper Join Date: Oct 2007 Location: Toronto, ON. Canada
| in my opinion motor servo BEC esc Rx/Tx in that order. dont settle on a budget ESC and transmiter. save for a high quality one . spend the money once, not twice. you already have everything needed, so just save your pocket money. |
| | #3 |
| Thanks - that mostly makes sense. |
| | #4 |
| Rock Crawler Join Date: Jul 2008 Location: San Diego
| My RTR did that also. When I turned it full lock I had no throttle. I would recommend a Tekin FX R combo with 45T. Wheel speed and torque. Saddle packs from Holmes Hobbies. Tekin #TT2104 FX-R + 45T Motor. stomer Has them for $99.99 The steering problems stoped when I installed the Tekin. Matt |
| | #5 | |
| Gold Star Baby! ![]() Join Date: Aug 2008 Location: Gone 1.1 crawling
| | #6 | |
i say bec because, even though its not manditory, its a great help in a crawler application. my rooster had problems supplying power to two 645MG servos. bec solved it. you dont have to follow my suggestion. this is just how i did it. in crawling, the servos demands alot of power from the ESC (depending on the servos you get). taking the load off the esc by using an external bec just gives it that extra boost. if you are not running rear steer or a dig i would say to hold off on the BEC untill you feel you actually need it. depending on the ESC's BEC, it would most likely be enough to power a single steering servo. i now run a CC Sidewinder and integy 55T with a HS-5645mg(steering) and a HS-225MG(dig) both powered by a CC BEC . and a Spektrum Dx3 and i am happy with this setup Last edited by BuzzKilla; 12-05-2008 at 10:03 AM. | |
| | #7 | |
Awesome; thanks guys! | |
| | #8 |
| Rock Stacker Join Date: Aug 2008 Location: (rock garden) Tempe
| i think it has to do with the weight in the tires and the crappy stock servo, I started with an rtr and have changed all the thing listed above, but I never had that problem with my original but I changed the servo out the 3rd day I would definetly go servo first. you will notice a huge difference....... |
| | #9 | |
| I joined the Band! Join Date: Oct 2008 Location: Bay Area
| | #10 | |
...The 55T makes a HUGE difference on speed - way more control. Now I just need my girlfriend to pick the right servo to put in my stocking. :P | |
| Thread Tools | |
| Display Modes | |
