Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: My comp SWX
Old 12-07-2008, 02:31 PM   #1
Default My comp SWX
rockassassin is offline   Reply With Quote
Old 12-07-2008, 02:38 PM   #2
Old 12-07-2008, 04:46 PM   #3
Nice build did u re drill your skid plat for your dig to work and it looks like your skid plate is 180 is that true. I just got my SWX in im trying to get it dilled in be for i think about a dig
rctrav27 is offline   Reply With Quote
Old 12-07-2008, 07:39 PM   #4
Yeah I redrilled my skid for my trans, I moved it in a hair. thanks
Old 12-07-2008, 08:57 PM   #5
Well, I went out crawling today and I just can't get rid of that torque twist, on steep climbs. I was woundering if anyone had any ideas for me by looking at my setup. thanks
Old 12-07-2008, 09:06 PM   #6
revers your tranny
merrillon24s is offline   Reply With Quote
Old 12-08-2008, 06:15 AM   #7
Originally Posted by merrillon24s View Post
revers your tranny
It's already turned around for the dig......
And to rid yourself of TT maybe try messing with your rear upper link placement
mockknight is offline   Reply With Quote
Old 12-08-2008, 09:06 AM   #8
try stiffer springs on the left front and left rear of the rig and play with the oil weights also.
ROCKCAD is offline   Reply With Quote
Old 12-08-2008, 09:40 AM   #9
I am running 70 weight left rear, 50 weight right rear,and 30 up front. I can try and put a yellow spring left front. What should I do with rear link placement.thanks
Old 12-08-2008, 09:49 AM   #10
try to play with the shock mounts. at lest with mine i had to raise the left rear link about a half inch from my right rear.
tyler,
rockdawgtruggy is offline   Reply With Quote
Old 12-08-2008, 10:01 AM   #11
On the rear upper links try putting a 4-6mm spacer between the link and the chassis. Add a little more pre-load to the front side that is lifting.
Dewmerz is offline   Reply With Quote
Old 12-08-2008, 10:22 AM   #12
Thanks for the help, I will try these things tonight, and try it out on my practice course tonite.
Old 12-08-2008, 06:19 PM   #13
Well I got my HB rovers today going to swap them out with my HPI grabbers. I need to move some weight up front anyways. Lots of screws.lol:-(
Old 12-08-2008, 09:47 PM   #14
what kind of servo is that????
cruz*hotboxrc is offline   Reply With Quote
Old 12-08-2008, 10:55 PM   #15
ya what servo is that
Old 12-09-2008, 12:31 AM   #16
willipmartinni's Avatar
Default mayhem
are those standard width mayhem double fattys???
willipmartinni is offline   Reply With Quote
Old 12-09-2008, 09:03 AM   #17
Servo Airtronics 94359Z . Yes they are the standard width mayhems. I got HB rovers mounted up last night I hope to get some crawl time on them today. I will try and get some pics up with them mounted.
Old 12-09-2008, 10:30 AM   #18
I want to get a set of the rovers also I bought another set a double fattys last night I'm gonna mount them on. Let me know how they do.
broncoholic is offline   Reply With Quote
Old 12-09-2008, 11:26 AM   #19
meant to say what servo horn is that?
Old 12-09-2008, 01:16 PM   #20
JR racing servo horn. ckrccrawlers sells them.
