12-09-2008, 06:48 PM | #1 |
RCC Addict Join Date: Nov 2008 Location: Bunnell, Fl.
| Tire / Wheel Question
On my CR-01 the wheels have two holes on the inside to let air vent in or out as needed when the tires compress or expand. On my AX10 there is no holes, so the tires feel much stiffer. Does anyone put holes in the AX10 wheels to vent them or are they meant to be a little stiffer than say, the Tamiya type? |
12-09-2008, 06:50 PM | #2 |
RCC Addict Join Date: Nov 2007 Location: E.T.R.C.
Yes you need to vent them....Drill a 1/8th" hole in each wheel |
12-09-2008, 06:50 PM | #3 |
Quarry Creeper Join Date: Jan 2006 Location: hagerstown
Yes I have holes in all my axial rims I use 2 1/8'' holes in each
12-09-2008, 06:52 PM | #4 |
Quarry Creeper Join Date: Apr 2008 Location: Carson City
I always vent my wheels, if not they bounce. It depends on foam setup, and what you are going to do with your truck.
12-09-2008, 06:55 PM | #5 |
Pebble Pounder Join Date: Nov 2008 Location: South "O"
do mayhems come vented or do you need to drill holes in them
12-09-2008, 06:56 PM | #6 |
Cool, that's what I was thinking. The manual did'nt mention anything, but pretty much all the RC's I've owned had some kinda of vent hole in the wheels.
12-09-2008, 06:57 PM | #7 |
You need to vent them. Vent them through the screw hole.
12-09-2008, 07:44 PM | #8 |
Quarry Creeper Join Date: Jul 2008 Location: looking for that perfect setup
i always vent all my tires
12-09-2008, 09:53 PM | #9 |
Rock Stacker Join Date: Oct 2008 Location: Epsom
if you don't have a drill you can cut two small holes in your tire but try to drill a hole if you can
12-10-2008, 11:36 AM | #10 |
Rock Crawler Join Date: Jul 2008 Location: Chula Vista
| No you have to vent them. I searched the site and someone had actually lined up their vent hole with a screw hole so you can control the amount air or seal it up depending on the terrain. This is what I did to my Mayhem Double Phatty's and it works great Check it out: Different Breather hole on Mayhems Last edited by treday619; 12-10-2008 at 11:50 AM. |
12-10-2008, 05:22 PM | #11 |
Newbie Join Date: Dec 2008 Location: Stafford, Va
2 1/8" holes 180 degree's apart on mine.
12-10-2008, 09:05 PM | #12 |
I joined the Band! Join Date: Oct 2008 Location: Bay Area
Two 1/8th holes 180 deg apart dead center on the tire. Drill the holes in the tires not the rim works like a charm.
12-11-2008, 03:01 PM | #13 |
TN State Champ 11,12,13 Join Date: Oct 2008 Location: KTM Talk.com
What happens if you drill more than one hole or larger than 1/8"? Any gain or loss? I drilled 4 holes in my mrc and it seemed to bounce, is that my imagination?
12-11-2008, 03:07 PM | #14 |
Pebble Pounder Join Date: Aug 2008 Location: Boxford
mayb the foam is really stiif thats my guess
