12-22-2008, 06:34 PM | #1 |
Rock Stacker Join Date: Nov 2005 Location: Street
| will this work?
will this battery work well with a novak rooster crawler and 55t integy? http://www.ckrccrawlers.com/shop/ind...oducts_id=1120 I dont know about the 11.1v |
12-22-2008, 06:37 PM | #2 |
Quarry Creeper Join Date: Oct 2006 Location: Bland
the rooster is only rated for 7 cells or 2s lipo
12-22-2008, 06:45 PM | #3 |
any reccomendations on lipo?
12-22-2008, 09:19 PM | #4 |
Pebble Pounder Join Date: Mar 2008 Location: yes
Dynamite makes a pack for the mini-t that is 2s and 1900 mah. It is the perfect size to zip tie or velcro onto your upper links. It is preferable to attach a piece of plastic (I used the lid from an old tupperware dish -cut into triangle with holes drilled for ties) then velcro the pack to the plastic for easier removal.
12-22-2008, 09:27 PM | #5 |
Been there, done that Join Date: Jan 2008 Location: On the road
| How much are you willing to spend? Remember, you get what you pay for. MaxAmps has really nice lipo packs for good prices. Check em out http://www.maxamps.com |
12-22-2008, 09:36 PM | #6 |
Pebble Pounder Join Date: Jan 2008 Location: E. Concord
For crawling purposes I dont think the "best" batteries are needed. I currently use some "cheaper" lipos and the performance is the same of some of the higher end ones that I have tried also. As for a Novak product, I wouldnt go over recommended voltage input.
12-22-2008, 09:40 PM | #7 |
I wanna be Dave Join Date: Oct 2006 Location: Centered
Can't miss with Thunder Power either; they have a 1320 that fits perfectly on the Axial low CG tray. Just change the plug and your set (as soon as they come back in stock) but check your LHS also, they may have some in stock. http://www.horizonhobby.com/Products...D=THP13202SJPL |
