12-26-2008, 04:10 PM | #1 |
Pebble Pounder Join Date: Jul 2008 Location: bedrock
| sloppy
i removed the anodizing on every aluminum part on my crawler, now all the bearings are kind of sloppy,loose ,any way to snug them up? i just dont like it. |
12-26-2008, 04:14 PM | #2 |
RCC Addict Join Date: Jun 2008 Location: Mudville
what parts, how did you remove the ano? you may of taken too much off which is now allowing for loose fit. how do the parts look? shiney and clean, or dull and rough? |
12-26-2008, 04:19 PM | #3 |
i removed it from the axle housings ,c's and steering knuckles,they were a little dull so i polished them a little ,just not where the bearings ride
12-26-2008, 05:47 PM | #4 |
Newbie Join Date: Dec 2008 Location: the hills
Did you take the ano off the parts where the bearings ride? that would deff make the parts sloppy because you are taking space away from everything. What did you take the ano off with a sand blaster or something? Its probably going to be tough to get everything all tight again unless you get where the bearings ride reanoed. Thats just my 2 cents and im a noob so some elts chime in if they agree .
