12-27-2008, 07:44 PM | #1 |
Newbie Join Date: Dec 2008 Location: here
| stock esc and batteries and pre plan building
just making sure that what i saw is correct. on the axailracing website it says that i can run up to 10 cells, nimh i pressume? and what is this i hear on here that axial ax10 doesn't have brakes, but i thought it did. what batter connector and size does the battery need in order to fit on the esc? probly get batteries from www.cheapbatterypacks.com what type of battery is best 2/3a,4/5a, a,aa,aaa, 1/2a, 1/2sc, 4/5 sc, sc, i have not a clue on which to pick? what awg wire thickness 16, 18? Last edited by quarterpounder; 12-28-2008 at 12:28 AM. |
12-27-2008, 08:35 PM | #2 |
Quarry Creeper Join Date: Dec 2008 Location: Punta Gorda, Flo-rida
Yes it will run up to 10 cells, nimh or nicd on the RTR the esc doesn't have a brake there isn't actual disk brakes or anything like that, most aftermarket esc have brakes The rest someone else can help you with |
12-27-2008, 10:52 PM | #3 |
I wanna be Dave Join Date: Jun 2005 Location: drillin Holes for the man
the esc will run 10 cells. They do have a break . Its a forward brake reverse esc. It does not however have a Drag Break. The brake on the esc is only good for stoping not holding. I would suggest 2/3's a cells for a crawler.You need to make sure your charger will charge 10 cells before you go dumping the coin on the batteries. Most NiCd/NiMh chargers will only charge up to 8 cell packs. 8 cells is plenty for a crawler any way. If you want more power than that you would be better going with 3c lipo's. |
12-27-2008, 11:18 PM | #4 |
think i will order a 8 cell saddle pack with elite 1500 pack 16 or 18awg wire? what type of connector? and this charger http://holmeshobbies.com/product.php...3&cat=7&page=1, unless someone knows of a cheaper charger that works great, saving money is a plus for me. i think that charger would work great when i upgrade the stock esc to a mamba max, this way i can play with drag and all that. |
12-27-2008, 11:47 PM | #5 | |
12-28-2008, 12:29 AM | #6 |
so ac is house and dc is like a car battery? deans male or female on the esc? |
12-28-2008, 09:08 AM | #7 |
Rock Stacker Join Date: Nov 2008 Location: orange county
Male on the esc, female on the battery, I learned the hard and hot metal way!!!
12-28-2008, 11:55 AM | #8 |
Newbie Join Date: Aug 2008 Location: Pocatello
I have been thinking about that charger myself. It has about everything you could ever want on a charger. Doesn't it?
12-28-2008, 12:42 PM | #9 |
yeah i know, nicd nimh, lipo
12-29-2008, 09:48 PM | #10 |
what about the castle creations sidewinder, any good? is it programmable like the mamba max?
