Thread: Dna dig problem
Old 12-30-2008, 03:17 AM   #1
Default Dna dig problem
I have a dna dig on my artr chassis. The problem comes with the lower links. My links are inside the skid plate and chassis and I want to keep it this way. It keeps everything from getting hung up on rocks. The links hit the dig unit. I have seen and heard several different solutions to fix this. First put a spacer between the skid plate and the dig unit. (seems crapy) Second run a 4 link on the rear and it would clear. Third buy ckrc stage 2 competition upgrade kit (dont know if this would really fix the problem). I just want to know who is running dna digs and what your set up's are and your suggestions
shaggy is offline   Reply With Quote
Old 12-30-2008, 08:10 AM   #2
Use a spacer with the stock chassis. ( Itried it and it worked fine)
or
get a new chassis that was built with the DNA dig in mind.
helhedded is offline   Reply With Quote
Old 12-30-2008, 08:25 AM   #3
Stage 2 kit is not a resolution for this. You simply need space under it with a stock chassis. Now is a great time to upgrade to a comp chassis anyway, lol.
O.C.D. is offline   Reply With Quote
Old 12-30-2008, 08:35 AM   #4
Get a black widow chassis drilled for a DIG. It's cheap and it rocks!
MtnBkr is offline   Reply With Quote
Old 12-30-2008, 09:27 AM   #5
that's right.... I forgot that the dig still needs to be notched for triangulated lowers.
SCRATCH THAT!
Old 12-30-2008, 09:44 AM   #6
I just had the same issue with mine. I actually made a new skid plate that extended past the motor/trans and held the dig servo keeping the cg low. Drive shaft hit it when it flexed. So to lower the trans back down, I cut the inside mounts for the rear links. They now attach to the frame itself and no issues. The trans is right back down where is is supposed to be. I did have to remove the spacer going from the frame to the top links because the MIP driveshaft hit it. Works great!
41565chevelle is offline   Reply With Quote
Old 12-30-2008, 09:53 AM   #7
09 RCA champ!
i had to notch my DNA to clear the lowers on my CG-2. the aluminum is pretty thick on the lower corner of the DNA and i had no problem grinding an 1/8" or so notch in it.
rednck21 is offline   Reply With Quote
Old 12-30-2008, 10:07 AM   #8
<------ X2 on the black widow
inline6power is offline   Reply With Quote
Old 12-30-2008, 12:13 PM   #9
I have the new dna dig that is black plastic so i dont think notching it will help.
Old 12-30-2008, 12:26 PM   #10
I too had this problem with my stock skid and the DNA.:-( I ended up with the DNA Slingshot SE. But on the way I found there are solid Delrin skids for about $12, but if you want to try your hand at fabing one up check out www.mcmaster.com Part Number: 8575K115.
ynmech is offline   Reply With Quote
Old 12-30-2008, 04:22 PM   #11
I took a die grinder to the Dig unit and did a little clearance work. I even ground a little on the nut on the link. It is a tight fit but it does fit.
K Riccardi is offline   Reply With Quote
Old 12-30-2008, 04:23 PM   #12
09 RCA champ!
the housing is plastic now?
Old 12-30-2008, 04:31 PM   #13
WHAT??? must be a typo....
bighitbomber1 is offline   Reply With Quote
Old 12-30-2008, 04:53 PM   #14
My mistake it is NOT PLASTIC. I dont know why i wrote that. It is metal. What other chassis will work with the dig?
Old 12-30-2008, 05:07 PM   #15
Go with the slingshot, it is built with the dig in mind. Or try your hand at building one!
Old 12-30-2008, 05:10 PM   #16
TSK
Shelf queen
TSK's Avatar
CDW!
TSK is offline   Reply With Quote
Old 12-30-2008, 05:27 PM   #17
Just look to see what others are using...
http://www.rccrawler.com/forum/search.php?searchid=4335
LIKES2CRAWL is offline   Reply With Quote
