12-30-2008, 03:17 AM | #1 |
Quarry Creeper Join Date: Jun 2008 Location: Phoenix
| Dna dig problem I have a dna dig on my artr chassis. The problem comes with the lower links. My links are inside the skid plate and chassis and I want to keep it this way. It keeps everything from getting hung up on rocks. The links hit the dig unit. I have seen and heard several different solutions to fix this. First put a spacer between the skid plate and the dig unit. (seems crapy) Second run a 4 link on the rear and it would clear. Third buy ckrc stage 2 competition upgrade kit (dont know if this would really fix the problem). I just want to know who is running dna digs and what your set up's are and your suggestions |
12-30-2008, 08:10 AM | #2 |
Use a spacer with the stock chassis. ( Itried it and it worked fine) or get a new chassis that was built with the DNA dig in mind. Last edited by helhedded; 12-30-2008 at 09:27 AM. Reason: deleted the stage 2 mod |
12-30-2008, 08:25 AM | #3 |
RCC Addict Join Date: Feb 2008 Location: Hiatus..sutiaH
/\ Stage 2 kit is not a resolution for this. You simply need space under it with a stock chassis. Now is a great time to upgrade to a comp chassis anyway, lol. |
12-30-2008, 08:35 AM | #4 |
Quarry Creeper Join Date: Aug 2007 Location: Morrison Crawlerado
Get a black widow chassis drilled for a DIG. It's cheap and it rocks!
12-30-2008, 09:27 AM | #5 | |
that's right.... I forgot that the dig still needs to be notched for triangulated lowers. SCRATCH THAT! | |
12-30-2008, 09:44 AM | #6 |
Rock Stacker Join Date: Nov 2008 Location: orange county
I just had the same issue with mine. I actually made a new skid plate that extended past the motor/trans and held the dig servo keeping the cg low. Drive shaft hit it when it flexed. So to lower the trans back down, I cut the inside mounts for the rear links. They now attach to the frame itself and no issues. The trans is right back down where is is supposed to be. I did have to remove the spacer going from the frame to the top links because the MIP driveshaft hit it. Works great!
12-30-2008, 09:53 AM | #7 |
09 RCA champ! Join Date: Sep 2006 Location: Acworth, Ga
i had to notch my DNA to clear the lowers on my CG-2. the aluminum is pretty thick on the lower corner of the DNA and i had no problem grinding an 1/8" or so notch in it.
12-30-2008, 10:07 AM | #8 |
Pebble Pounder Join Date: Nov 2008 Location: fresno
12-30-2008, 12:13 PM | #9 |
I have the new dna dig that is black plastic so i dont think notching it will help.
12-30-2008, 12:26 PM | #10 |
Rock Crawler Join Date: Aug 2008 Location: Wine Country
I too had this problem with my stock skid and the DNA.:-( I ended up with the DNA Slingshot SE. But on the way I found there are solid Delrin skids for about $12, but if you want to try your hand at fabing one up check out www.mcmaster.com Part Number: 8575K115. |
12-30-2008, 04:22 PM | #11 |
Quarry Creeper Join Date: Jun 2008 Location: Sykesville MD
I took a die grinder to the Dig unit and did a little clearance work. I even ground a little on the nut on the link. It is a tight fit but it does fit. |
12-30-2008, 04:23 PM | #12 |
12-30-2008, 04:31 PM | #13 |
Pebble Pounder Join Date: Sep 2008 Location: Red Deer,Alberta
12-30-2008, 04:53 PM | #14 |
My mistake it is NOT PLASTIC. I dont know why i wrote that. It is metal. What other chassis will work with the dig?
12-30-2008, 05:07 PM | #15 |
Go with the slingshot, it is built with the dig in mind. Or try your hand at building one! |
12-30-2008, 05:10 PM | #16 |
12-30-2008, 05:27 PM | #17 |
I wanna be Dave Join Date: Jun 2005 Location: KENNEWICK, WA
