01-05-2009, 03:38 PM | #1 |
Pebble Pounder Join Date: Jul 2008 Location: bedrock
| strc rear lockouts
got them with stainless axles today,do they come with any spacers? i put them on today and they would move in and out,so i had to file a washer down to fit ,just was a pain in the arse. |
01-05-2009, 03:42 PM | #2 |
Pebble Pounder Join Date: Dec 2008 Location: Miami
| mine do the same. i didnt kno of this flaw till i got them. looks like u figured out how to fix the flaw though. ull be ok |
01-05-2009, 04:01 PM | #3 |
RCC Addict Join Date: Nov 2008 Location: Bunnell, Fl.
They did'nt come with any shims?
01-05-2009, 04:31 PM | #4 |
Quarry Creeper Join Date: Oct 2008 Location: Jamestown
If you look at RCP's axles: http://rcpcrawlers.com/product.php?p...&cat=29&page=1 you see that larger diameter on them that goes inbetween the two bearings in the shafts this is what the STRC ones are lacking and its why they have all the movement you can shim them but when you do all you are doing is moving the lock pin in closer to the Aluminum lock out so if you really want to do it the correct way they way to do it is to build a spacer that will go in between the two bearings |
01-05-2009, 07:43 PM | #5 | |
01-05-2009, 08:13 PM | #6 |
Rock Crawler Join Date: Aug 2008 Location: Alamogordo
I just run mine as they came, yeah there is some slop back there but i dont see it ever negatively affecting anything or screwing me over on a climb/gate or course.
01-05-2009, 09:40 PM | #7 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
i have there orange lock outs and axles and don't have any play....i did notice i needed extra bearings for the end of the lock outs............bob .... |
01-05-2009, 09:44 PM | #8 | |
Quarry Creeper Join Date: Sep 2008 Location: !! MOAB !!
01-08-2009, 09:49 PM | #9 |
i took my rear axle apart and see the play you guys are talking bout....my question is what is the I.D. of 1/4" brakeline....i don't have any on hand thats why i'm asking....i'm thinking of make a spacer from it, the strc axle is .196"....even though the axle would be out of the locker by only 1/32" that shouldn't be any problem i'm thinking.............bob .... |
01-09-2009, 04:23 AM | #10 | |
If the brake line is the wrong size?? You can pick up some shims at your LHS for cheap!! Problem solved.. | |
01-09-2009, 04:55 AM | #11 |
The side play doesn't cause any issues. Now the soft steel the axleshafts are made of... thats a problem |
01-09-2009, 05:19 AM | #12 |
how long/wide are the shims....i need 18/32" of spacer between the bearings.... whats a good axle to get then................bob .... |
