01-14-2009, 04:16 PM | #41 |
Quarry Creeper Join Date: Jul 2008 Location: Asheboro N.C
Twenty1eleven Chassis and 4 link
01-14-2009, 04:17 PM | #42 |
Adilynsdad too! Join Date: May 2004 Location: G ville
My favorite mod is Raptorman...
01-14-2009, 08:40 PM | #43 |
01-14-2009, 09:10 PM | #44 |
Quarry Creeper Join Date: Sep 2008 Location: Where there are no rocks.
My dig and dx3r, should've spen the money right off the get go. Like people say on here ALL THE TIME! get a good radio. Anyone need a hitec agressor am 2ch?
01-14-2009, 09:14 PM | #45 |
01-14-2009, 09:16 PM | #46 |
01-19-2009, 09:03 PM | #47 |
Newbie Join Date: Oct 2008 Location: BFM
Deanodizing everything, i'm color blind lol, Dig definatly!
01-19-2009, 09:39 PM | #48 |
Quarry Creeper Join Date: Dec 2008 Location: Post Falls, ID
| soften and sipen
not my fav, but i haven't heard it on here yet, if you run stock tires, make them a little softer and sipe them or remove some material with mister dremel. wd40 or simple green both are suppose to work as well as diesel. did a little of both before i got panthers, which are also nice! |
03-16-2009, 12:09 PM | #49 |
TN State Champ 11,12,13 Join Date: Oct 2008 Location: KTM Talk.com
| Gc-2
My favorite mod would have to be the GC-2 chassis. Soooooo much better than stock. |
03-16-2009, 01:04 PM | #50 |
Quarry Creeper Join Date: Dec 2008 Location: Punta Gorda, Flo-rida
Oh so many, ill go in order of most important... 1. SWX chassis 2. hpi Rock grabber tires 3. steering servo 4. losi shocks 5. dig 6. aluminum c's and knuckles. |
03-17-2009, 11:47 AM | #51 |
I wanna be Dave Join Date: Feb 2009 Location: 20 miles southeeast of downtown Sacramento
New to this but so far the HB rovers have helped the most along with the Hobbieco c170 servo. I have the stick battery on the rear axle, super soft springs on the front and stiff ones on the rear with a spacer on the drivers rear. Mounted the lower links inside the rails, 4 linked the uppers, turned the shocks upside down moved the spacers inside and mounted them outside axle mounts. Works Ok but needs a little more tweaking. Just got a futaba 3pk 2.4 and have a r2d trans, holmes 500 puller, lipo 3 waiting to go in. fxr along with vanquish high-steer knuckles on order. It ne3ver seems to end.
03-17-2009, 12:43 PM | #52 |
Newbie Join Date: Dec 2006 Location: Sacramento
(1).5 lbs in each front tire (2)internal spring setup (3)45 turn intergy (4)11.1 Lipo (5)stamped drive shaft upgrade (6) 9100 steering servo next will be a metal gear trans NO dig. Its a a novice class killer |
03-17-2009, 01:16 PM | #53 |
Newbie Join Date: Jan 2009 Location: Marysville
fav mods have been; 1.)SWX 2.)batt on front axle 3.)wheel weights |
03-17-2009, 01:30 PM | #54 |
Quarry Creeper Join Date: Apr 2008 Location: Racine
Mayhem DP was the single mod / upgrade that I saw the most improvement with so far.
03-17-2009, 01:33 PM | #55 |
I wanna be Dave Join Date: Jan 2009 Location: By a lake in Thornton
55t new tires (anything is better than the lizards) and rebuilding the shocks |
03-17-2009, 01:48 PM | #56 |
Quarry Creeper Join Date: Apr 2006 Location: 5280
im going with 3 fav mods -DX3R -DIG -400oz servo everyone replaces tires, chassis (ok not everyone) and bodies...but the nicest for me was those 3...the servo and radio especially make things so smooth |
03-17-2009, 01:53 PM | #57 |
I joined the Band! Join Date: Oct 2008 Location: Bay Area
My favorite MOD is the band THE JAM If your a bit confused then your to young. |
03-17-2009, 02:30 PM | #58 |
RCC Addict Join Date: Aug 2007 Location: Marshalltown
top three mods: 1. SWX Chassis 2. Tires 3. Battery on axle |
03-17-2009, 03:12 PM | #59 |
Quarry Creeper Join Date: Dec 2008 Location: Route One
the first mod was battery placement. I would feel like a RETARD with a pound weight in the highest part of my rig so I stuck it on my upper front links for a fdew days then I made the servo. batt tray on the front axle. making a Low COG frame coz it works and was free |
03-17-2009, 06:03 PM | #60 |
Quarry Creeper Join Date: Jun 2004 Location: dsm IA
#1 losi claws with memory foam #2 weighted and drilled wheels #3 mirror trans #4 4link in rear #5 full droop #6 practice,practice,practice |
