01-06-2009, 10:18 PM | #1 |
Newbie Join Date: Jan 2009 Location: bakersfield
| Link skids
hi everyone , before I got a ax10 I read somewhere on here people were putting some kind of plastic on the skids to make them slide better and protect them but I've searched on here and I can't find it now. What is everyone doing for this? I have the artr with the rooster crawler and 55 turn motor and a couple of other mods and I really like it! Well thanks in advance!
01-06-2009, 10:19 PM | #2 |
sorry I meant links
01-06-2009, 10:47 PM | #3 |
I wanna be Dave Join Date: May 2006 Location: FOUR 8 OH
Delrin tubes.... or just make some new links from solid delrin.
01-07-2009, 12:39 AM | #4 |
Quarry Creeper Join Date: Dec 2008 Location: fairfield
i think i read somewhere someone sliding the tubes off pens over their links
01-07-2009, 01:32 AM | #5 |
Rock Stacker Join Date: Feb 2008 Location: Bay Area
Make some out of solid delrin. Very easy to make with Jeepindoug's link drill bushing Just measure, drill, tap and presto!
01-07-2009, 01:48 AM | #6 |
Quarry Creeper Join Date: Jul 2008 Location: Saskatoon in summer, Las Vegas in winter.
There is a product called Slick Sleeves... Check out the vendor section, I am sure they are listed in there. PM me if you can't find them, I will get you a link... Here you go... http://www.rccrawler.com/forum/showt...hlight=sleeves Last edited by Prostreet; 01-07-2009 at 02:06 AM. Reason: Added Link... |
01-07-2009, 06:24 AM | #7 |
Rock Stacker Join Date: Mar 2008 Location: Boise
01-07-2009, 06:54 AM | #8 |
Quarry Creeper Join Date: May 2008 Location: ncrccrawlers.com
Look up "acetal rod" on www.mcmaster.com and get the 5/16" solid black rod ($0.79 per foot).
01-07-2009, 07:14 AM | #9 |
Thanks
01-07-2009, 01:39 PM | #10 |
Newbie Join Date: Sep 2008 Location: indy
I have ordered from smallparts.com without ant problems. They also have derlin rod. http://www.smallparts.com/Delrin-Ace...AF&pf_rd_t=301 |
01-07-2009, 07:43 PM | #11 |
Thanks everyone. That's what I was looking for. Can you bend delrin to make the 30* links?
01-07-2009, 08:14 PM | #12 |
01-09-2009, 05:08 PM | #13 |
Newbie Join Date: Jun 2006 Location: iva
i cut carbon arrows with a dremel and used them as skids for my links , stiff and slide good and cheap
01-09-2009, 05:12 PM | #14 |
Newbie Join Date: Jan 2009 Location: Allentown
Has anyone tried just simply slipping a drinking straw over their links? It's quick, easy slippery and did I mention....cheap? Dunkin Donuts didn't even see me taking 5 at once.......:-P |
01-10-2009, 08:17 PM | #15 |
Rock Stacker Join Date: Jun 2008 Location: Wyoming
01-10-2009, 09:04 PM | #16 |
Pebble Pounder Join Date: Mar 2008 Location: yes
I am curious about that too. Seems like a good quick fix.
01-12-2009, 10:36 PM | #17 |
Well I ordered some delrin from mcmaster today. When I get it im going to make some links. Does anyone know what size drill and tap I need? I am going to put it in the lathe to get the hole in the center. Thanks everyone for pointing me in the right direction. Ill post pictures after i make them. What should i do next? I have the saddle pack on the front axle, weighted and drilled wheels, rooster crawler, and i have the artr?
01-12-2009, 10:43 PM | #18 | |
Pebble Pounder Join Date: Feb 2008 Location: Canterbury
01-12-2009, 10:50 PM | #19 |
Pebble Pounder Join Date: Jan 2007 Location: H D
the sleeves look cool |
01-12-2009, 11:06 PM | #20 |
RCC Addict Join Date: Jun 2007 Location: Indian Village Pontiac
Sleeves over the links are a temporary fix. Even the slick sleeves only last so long. Solid delrin/acetal is the way to go. I make High Clearance Dogleg black delrin/acetal links from 1/4" sheet that clear any shocks and are indestructable so far. Heating and bending delrin/acetal creates a change in the molecular structure cuasing it to turn brittle. I have tested heating and bending extensively and found the best way is to cut the shape out and round the edges. My Delrin Links: the new version does not have the holes for strength These work great and clear even the large diameter Revo Shocks!! |
