01-09-2009, 02:38 PM | #1 |
Newbie Join Date: Sep 2008 Location: spilsby,lincolnshire
| bent or slippy straight?
hey all , im DENTY from over in UK (EAST COAST CRAWLERS). just wanna ask what sort of setup you all use on your bottom links? standard ally straight , bent rear straight front, double bent. delrin?? what you all got? im running double straight delrin but thinking about going to double bent for the clearance... |
01-09-2009, 02:58 PM | #2 |
Rock Crawler Join Date: Aug 2007 Location: Atlanta
I used to run all 4 lowers bent, untill my newest rig. Now i have all 4 straight with aluminum links. My next project will have bent links, its definitely something thats needed! |
01-09-2009, 03:09 PM | #3 |
Pebble Pounder Join Date: Mar 2008 Location: yes
why not bent delrin?
01-09-2009, 03:13 PM | #4 |
Newbie Join Date: Nov 2008 Location: Frankfort
I run bent delrin top and bottom on my slingshot
01-09-2009, 05:07 PM | #5 |
HUNNY wheres my heat gun ?? im gunna go bend sum rod!!
01-09-2009, 05:21 PM | #6 | |
Newbie Join Date: Jan 2009 Location: Allentown
However, the bent links drop the driveshaft below the links and expose them to scraping..... Then again, the way I crawl, a little more rotational contact from ANYWHERE might help...... | |
01-10-2009, 08:15 PM | #7 |
Rock Stacker Join Date: Jun 2008 Location: Wyoming
I run straight delrin on all fours. I didn't like my drive shaft turning my crawler around with the bent aluminum, plus the aluminum seemed to drag more.
01-10-2009, 08:53 PM | #8 |
Rock Stacker Join Date: Mar 2008 Location: Long Island
I run bents on my WK. On my AX-10 straight aluminum until about a month ago, I switched to straight delrin.
01-10-2009, 11:23 PM | #9 |
Pebble Pounder Join Date: Dec 2008 Location: Miami
i run straight links on my swx. on top of the fact that u cant run bent links on the swx, wouldnt run them regardless. you get the same clearance with bent links or str8 links. the difference is that when you have bent links what rubs on the rock is the drive shafts. and when you have str8 links what rubs is the links. i would rather protect my shaft then my links. there is a 90 percent chance i will be switching to delrin strraights though.
