01-10-2009, 05:58 PM | #1 |
I joined the Band! Join Date: Oct 2008 Location: Bay Area
| What Shocks to get links plz
What size space and screws do you guys use on your Ax10 to move your shocks back to the 3rd mounting hole? and where did you get them? I have seen planty of spacers but they are all diffferent sizes and I have never seen the screws. I am using the stock shocks and If I move them back they rub/bind. I inverted the front ones to get by this problem. Is there a better solution? or shock? Thanks. Last edited by grimgard; 01-10-2009 at 09:33 PM. |
01-10-2009, 07:04 PM | #2 |
Newbie Join Date: Jan 2009 Location: Pagosa Springs
| This might help. Traxxas.com and look for the traxxas t-maxx 2.5 shocks. They lower your car about 1/2' no need for the holes.. |
01-10-2009, 07:08 PM | #3 |
Pebble Pounder Join Date: Mar 2008 Location: yes
That's what I run and it works AWESOME! |
01-10-2009, 07:28 PM | #4 |
really? me too! cool bro!
01-10-2009, 08:49 PM | #5 |
What about the spacers? The T-max shocks are sold in packs of 8? If I can use the stock shocks It would be better since I just bought some new springs for them. Has anyone tried these? http://www.axialracing.com/ftp/ax10o...al_shocks.html What about these? http://www3.towerhobbies.com/cgi-bin...?&I=LXVNT1&P=Z and do they mount up with out any mods? How long are they? Last edited by grimgard; 01-10-2009 at 09:07 PM. |
01-11-2009, 09:49 AM | #6 |
Newbie Join Date: Jan 2009 Location: Allentown
If you're looking to lower your Axial, you can't use those inside holes without spacing your shocks away from the end of that framework, because the spring perch hits it. You can space the shocks inboard a little more, and use whatever spacers you need, made from the Axial tubing (after driling it out to accomodate a 3mm bolt) or from derlin tubing/rod. Personally, I'd look into shorter (T/E Maxx) shocks. You can still use your new springs on them.... That or take your shocks apart, and put limiters inside them, shortening them internally. |
