01-10-2009, 07:34 PM | #1 |
Newbie Join Date: Jan 2009 Location: Pagosa Springs
| Help me please..
I have just bought a 65 turn motor by integy and a CC-Sidewinder. ever since i installed it PERFECTLY. my rig has been making gear noises.. such as like click constantly througout the time ive been running it.. if you can help me please do.. ill awnsers any questions needed |
01-10-2009, 07:50 PM | #2 |
Gettin’ back on the horse Join Date: Feb 2006 Location: Hoonsville
gear mesh on your pinion and spur? or maybe metric vs. standard spur and pinion?
01-10-2009, 07:50 PM | #3 |
Pebble Pounder Join Date: Mar 2008 Location: yes
Have you disassembled your trans and axles to check for damage? If not, then try it. If so, then I don't know how to help you.
01-10-2009, 07:50 PM | #4 |
RCC Addict Join Date: Oct 2007 Location: Commerce Twp.
Make sure that the set-screw on the pinion gear, is not hitting the spur gear.
01-10-2009, 08:16 PM | #5 |
Also check if anything is hanging up in the motor. Blow it out or visually inspect it for debris.
01-10-2009, 10:33 PM | #6 |
Rock Crawler Join Date: Sep 2008 Location: Mid Mo.
It is most likely the set screw. If it is not hitting bad enough to chew the spur leave it be and run it.
01-10-2009, 11:34 PM | #7 |
Quarry Creeper Join Date: Nov 2008 Location: Lightin' The Desert In
01-10-2009, 11:40 PM | #8 |
could it be the motor? thats where it soudns like its coming from.. maybe since its brand new? the brushes maybe?
01-10-2009, 11:42 PM | #9 |
01-11-2009, 12:06 AM | #10 |
Pebble Pounder Join Date: Oct 2008 Location: Fresno
Pinion set screw.... it's actually kind of hard NOT to have it hit. I have my pinion all the way back and still get a little click out of it. That's my quess anyways.
01-11-2009, 12:24 AM | #11 |
Quarry Creeper Join Date: Sep 2008 Location: by a river
ive got the same problem with the same motor.but now my motor isnt turning over.dnt know y
01-11-2009, 12:30 AM | #12 |
Rock Crawler Join Date: Sep 2008 Location: Kennesaw
Does the motor not click when you push the car the other direction?
01-11-2009, 05:06 AM | #13 |
01-11-2009, 05:44 AM | #14 |
RCC Addict Join Date: Nov 2008 Location: Bunnell, Fl.
| It sounds like the motor brushes, my Novak 55t does the clicking noise, but only in reverse. I've read on here that it will go away as the motor breaks in and the brushess seat better.
01-11-2009, 09:03 AM | #15 |
Rock Crawler Join Date: Dec 2008 Location: Appleton, Wi
01-11-2009, 10:50 AM | #16 |
Newbie Join Date: Dec 2007 Location: St.George, UT
my 55 turn motor did the same thing, only in reverse,, which leads me to believe that the brushes were not broken in yet.. because i checked everything and couldnt find the problem ... and in time the problem just went away>>> so now that my brushes are broken in... no clicking>>> |
01-11-2009, 10:58 AM | #17 |
thats what my dad said! thanks!
01-11-2009, 12:21 PM | #18 |
Newbie Join Date: Jan 2009 Location: New Orleans
My 55t integy motor made an audible clicking in it for the first 30 min or so of run time, now it is silent. I guess it had to break in. No problems with spur/gear mesh/set-screw contact.
01-12-2009, 12:55 AM | #19 |
Quarry Creeper Join Date: Apr 2007 Location: Harrisville, UT
Check all around the spur, make sure you've got plenty of clearance, it could also be your u-joints on your drive shafts |
