01-11-2009, 05:10 PM | #1 |
Quarry Creeper Join Date: May 2008 Location: Franklin
| Axial Trans output shafts
Alright I found info on Yota's CDW Chromoly outputs. I was wondering if anyone else made improved output shafts for the AX10 trans. Thanks in advance for all the help Goz.
01-11-2009, 05:26 PM | #2 |
As far as I know,Anthony is the only one that makes good outputs for the masses. I had some custom stainless outputs made a very long time ago. Still going strong. I've lost his contact info though.
01-11-2009, 05:29 PM | #3 |
Rock Crawler Join Date: Nov 2008 Location: Roseville,Ca
I know ckrc has some. http://www.ckrccrawlers.com/shop/ind...oducts_id=1590 |
01-11-2009, 05:48 PM | #4 |
01-11-2009, 06:14 PM | #5 |
Newbie Join Date: Dec 2008 Location: Ludington
yah. i hate the stockers
01-11-2009, 07:37 PM | #6 |
Rock Crawler Join Date: Sep 2007 Location: 42N 88.02W
| Go with CDW a.k.a. Anthony a.k.a. yotachump, his stuff is 100% high quality and well designed.
03-25-2009, 01:32 PM | #7 |
Newbie Join Date: Mar 2009 Location: East County
i have been trying to get a hold of yota , i would like to buy a set or two of these are they still avail? Thanks! Dan |
03-25-2009, 03:28 PM | #8 |
RCC Addict Join Date: Nov 2008 Location: I don't think theres rocks in Florida
buy em once. With the cdw's you'll be happy!
03-25-2009, 06:51 PM | #9 |
Rock Crawler Join Date: Jun 2008 Location: dublin
yotachumps outputs .done
03-25-2009, 07:41 PM | #10 |
I would have bought the CDW's but found a set of CKRC ones on E-bay for $10.00. Which gives me a spare for the front. As with the Hot Racing Dig you have to use their rear output shaft. At least it's steal.
03-26-2009, 10:01 PM | #11 |
Pebble Pounder Join Date: Mar 2008 Location: K-ville
Do these CDW's git rid of the flat and add a hole? Will they work with the stock driveshafts or will I need to change them? I need to go to something better in the shaft department because I was popping stocks and went to stampede's and now I'm popping them. Thanks for the help. |
04-06-2009, 11:39 AM | #12 |
Pebble Pounder Join Date: Apr 2009 Location: Worcester
I'm trying to plan ahead here and don't have an ax10 yet, so excuse my ignorance. These go in the center tranny correct? Last edited by knuckleslammer; 04-06-2009 at 11:45 AM. |
04-06-2009, 01:02 PM | #13 |
Correct, they bolt to (sandwich) the large gear on the bottom of the tranny and the driveshafts mount to the ends (where the flat spots are located).
