| | #1 |
| Rock Crawler Join Date: Nov 2008 Location: I don't think theres rocks in Florida
| Whats your preference, and is there a reason? What are the benefits of having it on the right or left of the axle as opposed to the center? |
| Sponsored Links | |
| | #2 |
| Quarry Creeper Join Date: Dec 2008 Location: Suburbs
| I'd try the search button first...but off set you have the option to put a battery pack, usually lipo up on that plate. It you keep it centered, you can run a split pack on each side of the servo. I leave it centered because I run the split packs. Helps to lower the CG a little bit more than the offset servo with the battery pack on that plate. Just get one that you can use a 4 link set up on, not the stock 3 link that comes on the truck, you're better off. Helps on torque twist too. |
| Thread Tools | |
| Display Modes | |
