| | #1 |
| Newbie Join Date: Jan 2009 Location: Orange
| A friend of mine has an 8 cell split pack he wants to give me for my ax10 but I'm new to electrics and don't know too much about voltages. So i was wondering if you guys think an 8 cell pack would be too much for the stock electronics on an RTR. Thanks |
| Sponsored Links | |
| | #2 |
| Rock Crawler Join Date: Dec 2008 Location: Appleton, Wi
| Heck no! The stock ax10 esc is good for 10! Hook it up and dont look back! |
| | #3 |
| Pebble Pounder Join Date: Jan 2009 Location: Crestview
| the correct answer is, just depends what ESC you are using. read the data sheet for it. |
| | #4 |
| sweet! i was worried about it burning something up. I also plan on putting in a new esc and motor when i get the money... edit: looked at the spec sheet for the stock esc and it says i can run 5-10 cells. Thanks for the help Last edited by rockindacheeks; 01-26-2009 at 07:32 PM. |
| | #5 |
| I wanna be Dave Join Date: Jun 2005 Location: With my family
| go for it! like said above it will handle 10 cells. |
| | #6 |
| just make sure any new esc's are also good for 8 cells or you will burn it up. Just because the stock ax10 esc is good for 10 doesnt mean all of them are. |
| | #7 |
| Rock Crawler Join Date: Jul 2008 Location: San Diego
| I'm 10 cells and 55t motor 10t pinion 90t spur. Its fun to run. Next battery will be a 3 cell Lipo! 10 cell=12volts 3 cell Lipo=11.1 volts--my friend is running a 8 cell sadddle pack with a 55t and loves it. Matt |
| | #8 | |
Kinda a dumb question... does the number of cells mean longer run times? or does it effect the performance of the car itself? Thanks | |
| | #9 |
| Normally more cells =more voltage. The cells are all for example 1500mah so the pack will be 1500, but there is ways to put together packs for more run time. Its just not needed. On a 8 cell pack a lot of guys are running 45min.+ much longer after that your electronics start getting too hot and thats not real good. Even if my truck is still going strong Ill still put it aside after 45min. just to give the truck a rest and let it cool down. |
| | #10 |
| Thats awesome! 45 min is a long time. I bought this car so i can give my 5B a rest and have something else to do while the headache from the exhaust goes away. So Ill just keep an eye on the electronics to make sure they dont get too hot. |
| Thread Tools | |
| Display Modes | |
